Supersix Motorsports Stage 3 - Mustang Evolution
Old 12-23-2006, 01:29 PM   #1
Smile Supersix Motorsports Stage 3
I have a couple of questions. First of all, I have been looking around to get my 1998 3.8 Liter V6 Pony more power and I have been looking at turbochargers and superchargers, but I have heard that they can decrease an engine's life and it will also require alot of engine and car modification and alot of money to keep the turbo or supercharger working. So I began to look into the superstreet Motorsports Stage 3 Powerpacks and they say that it will give my car around 100 horses. Does anybody know whether my car will have 250 horses by adding the stage 3 to my car and is the stage 3 worth 2 grand. I talked to another mustang guy and he said that the stage 3 will not give me 250 horses unless I add some sort of power adder. Is this True
Thanks for the responses
red_pony is offline   Reply With Quote
Old 12-23-2006, 02:37 PM   #2
KyleUSAF's Avatar
Send a message via AIM to KyleUSAF Send a message via MSN to KyleUSAF
Re: Supersix Motorsports Stage 3
i believe brent is doing a stage 3 swap into his car from the same company. It will depend on your setup and cam etc, but i think he is looking to be close to that.
I'm sure he'll chime in
Originally Posted by Darkshadow
I could say nothing for my complete awe. He then. confidantly, purchased the gallon.
KyleUSAF is offline   Reply With Quote
Old 12-23-2006, 02:57 PM   #3
Smile Re: Supersix Motorsports Stage 3
If you can, can you tell me what cam he is using and what parts work the best when ordering the stage 3. I want to order the stage 3 so I can be close to 250 horsepower if that is possible
Thanks
Old 12-23-2006, 03:08 PM   #4
I don't have the Stage 3 but I have the equivalent from Rpm-Mustangs.com
I have a 224/230 cam but I have a 4.2L Crankshaft so that makes a difference when determining your cam. I have a Cut and Weld Upper Intake and a Stage 3 Lower intake with Stage 3 heads.
Old 12-23-2006, 03:25 PM   #5
slvr2000stang's Avatar
The end result will depend on how aggressive you want to go and how well matched all the parts are.
There are basically three places that can provide you with quakity parts.
RPM-Mustamgs.com (Mik)
SupersixMotorsports.com (Tom)
DelkPerformance.com (Matt)
On a 3.8 250 will be tough. going to a 4.2 you should be able to do it.
Be aware it will not be cheap. Buy the best parts you can afford, it will payoff in the long run.
Custom Delk motor now DOA
2003 SVT Lightning #1059 of 4270
2000 Vert 4R70W
Only buy from vendors that test and stand behind their products
slvr2000stang is offline   Reply With Quote
Old 12-24-2006, 01:09 AM   #6
Thomas91169's Avatar
you can make 250 n/a on a 6er, it just takes a bit of money and know how. Ive seen a few on here back in the days it was mainly a V6 site with 230/240hp still a 3.8L.
id go with a 4.2L and a really nice top end combo from any of the above mentioned vendors, it will be a very nice naturally aspirated combo, and later on if you decide to go forced induced, it will be that much better, though you will have to decide now on if you want naturally aspirated, nitrous, or blower grinds on your cams.
simply adding a SC or TC will not adversely affect the livespan of the motor unless you forget to change oil. Trying to run ungodly amounts of boost and/or not tuning the setup by a reputable tuner will. DarkShadow is running i believe 11psi ish on a turbo setup on his 3.8l with a stock motor/heads.
-Thomas-
Old 12-24-2006, 02:16 AM   #7
So, final question, is it worth to buy the supersix motorsports if I want more power for 2 grand?
Old 12-24-2006, 02:20 AM   #8
Yes
Old 12-27-2006, 07:03 PM   #9
silverstangboy's Avatar
build a stroker v8, and put 350 to the wheels... (sorry I had to!)
all kidding aside In the past I heard alot of hear-say about the high quality of RPM mustang
also almost bought the kit from supersix motorsports
don't know much about delk, but if its the same guys from TN, then I hear they do excellent dyno tuning
93 mustang notch
~450hp 331 stroker - Sold
Super Six Motorsports 67mustang97 Pre-2005 V6 Mustang 3 01-03-2010 08:25 PM
super six motorsports sledgehammer Pre-2005 V6 Mustang 8 01-07-2008 11:22 PM
HPA Motorsports eddied Mustang Audio & Video 1 12-18-2005 02:27 AM
New from Ford Motorsports Danger Dude Pre-2005 V6 Mustang 45 05-20-2005 08:55 AM
12:40 PM
