manual trans oil - Mustang Evolution
Old 12-26-2006, 09:29 PM   #1
00stang3.8's Avatar
manual trans oil
I was wondering about how frequently the oil of a manual trans needs to be changed. I have a '00 3.8 stick that has 63,000 on it and i dont know if the trans oil has ever been changed, I got the car in '03. Is this a hard thing to do? or is it worth the money to take it in and have it done?? also it there anything you can tell by looking at the old oil, such as tranny condition??
thanks alot for any advice.
00stang3.8 is offline   Reply With Quote
Old 12-27-2006, 01:49 PM   #2
Scut95's Avatar
Re: manual trans oil
If you dont know if it was changed or not, i would just do it to make sure. I just did mine and it was a little brown, i have 68,000 on my car. The drain and fill plugs are in the passenger side of the tranny. Just take a 3/8 ratchet and put it in the hole. It's a perfect fit, they will be tight though so you might hafta put some elbow grease into it. Make sure you can get the fill plug loose first before the drain plug, otherwise you could be screwed. An easy way to fill the tranny is to fill it up throguh the shifter but you would have to take the shifter out to do that, if not just see if you can get it in the fill plug. It's a bit tricky because of the tight space. Good luck
Old 12-27-2006, 09:01 PM   #3
00stang3.8's Avatar
thanks alot for the input but the only thing im worried about is filling it back up? How much do you put in?? How do you know when there is enough in there? and what kind of oil do you use??
Old 12-28-2006, 07:03 AM   #4
I would change it every year if you have the area to do it yourself else every other year. It lets you see the fluid and find out if you have any issues before they become major issues. It takes like 3 quarts (maybe 4) of fluid, most run Mercon/Dextron 3 (oem fluid what came in it) you basically pull the drain plug and fill plug and after its drained put the drain plug in and use a little pump to fill up the trans through the fill plug until the fluid starts to run back out of the hole and you are done. Just make SURE the car is on level ground~
Old 12-28-2006, 03:28 PM   #5
00stang3.8's Avatar
alright sounds good, thanks!
'04 GT Swap-out automatic trans for 6-speed manual ctogni1 1996-2004 Mustang GT 1 01-14-2010 01:29 AM
manual trans question andreas 1979-1995 Mustang GT 3 04-26-2007 12:25 PM
Just bought a 2006 V6 Manual trans Pony pkg Rick0636 Pre-2005 V6 Mustang 17 02-22-2006 08:18 AM
2006 V6 Manual Trans - Bucks in 1st Gear in AM lovcom Pre-2005 V6 Mustang 9 11-20-2005 09:08 AM
05 v6 manual trans.. MonteCitan Pre-2005 V6 Mustang 29 01-07-2005 04:40 PM
11:06 AM
