Engine problems!?!?!?!? - Mustang Evolution
Old 07-13-2010, 01:29 PM   #1
OK, so three times now a wrench light apperared next to my speedometer, and when it does my engine runs really rough, and my gas pedal just basicaly stops working. Aftet happening today i realized it happens after everytime i fill my gas tank. The only mod i have done to it is duels, but since i have more air flow will that make my engine run "lean" if im not running a high octane?? Now, im not sure what that means but ive herd the term used when taking about air fuel mixtures. PLEASE give me your input on what this could be!!!
Blackbandit is offline   Reply With Quote
Old 07-13-2010, 01:38 PM   #2
Re: Engine problems!?!?!?!?
Wow....there are a lot of details we will need here.
Your engine isn't running lean now because of your duals unless something went wrong hooking up your O2 sensors or you disconnected something and didn't put it back together right and now have a bad leak.
And octane rating has nothing to do with running rich and/or lean.
Ok, with those details cleared up....what car do you have? Year? Model?
Does this light stay on for a while when it comes on? If so, go fill up, drive to a local autozone, oreilly's, or advanced auto and they will scan your car for error codes which will then tell you exactly what is wrong.
Old 07-13-2010, 03:06 PM   #3
the details: 2005 v6 mustang (4.0), 5 speed with 31500 miles. Now when the light comes on i turn the car off, and the turn it back on and then its fine. So the light will only stay on untill it restart it.......as far as i know cause when it happens i immedialy restart it. What do you think??
Old 07-13-2010, 03:55 PM   #4
ponyboy94's Avatar
I had the same problem with a differant car when fueling. What I found out was make sure the car is shut off when fueling, do not try to top off the tank just fill it and make sure u turn your cap acouple of times past lock. This solved my problem I know how it sounds but it has to do with breathing and vapor lock. I never had a problem ever again. Ponyboy
ponyboy94 is offline   Reply With Quote
Old 07-13-2010, 04:20 PM   #5
well, i went to auto zone and when they ran the scan two codes came back. One said i had a faulty throttle boddy or its stuck closed and or bad connecions, and the other said: defective app sensor, multiple control system failure detected, or failed ECM....So i guess i should go to the ford dealer????
Old 07-14-2010, 04:17 PM   #6
Zebs5408's Avatar
NOOOOO...not yet, i believ the intake could be a problem, could be a throttle cable sticking or something but that usually make the gas pedal floored lol,,,anyway my first thought was fuel pump or injectors....are u filling the car ALL the way up? like clicking eveyr cent into it?
04' mustang 3.9 40th Anniversary Edition- (V2 Vortech Supercharger, 38# injectors, 3.73 gears w/ T-lok, Predator Diablo, Mac cold air intake, Port & polished upper AND lower intake manifold, Mac Long Tube Headers, Mac o/r H pipe, flowmasters, 2.5 flowmaster tips)
03' Mustang GT (20" Cobra R's, 40 series Flowmasters)
Zebs5408 is offline   Reply With Quote
Old 07-14-2010, 05:03 PM   #7
Well when i fill it i usally "basicaly" fill it but not squeezing every cent. I called the dealership today and they were going to charge me 92 bucks to run a dianostic, But your saying not to....What should i do???
Old 07-14-2010, 10:47 PM   #8
ponyboy94's Avatar
I think I would clear the code and drive it and see what happens the next time you put in gas and see if it does it again we had codes that didn't make sence and it didn't happen again, it sounds wierd but it worked. Good luck ponyboy
Old 07-15-2010, 08:45 PM   #9
Zebs5408's Avatar
Sorry i haven got back to u quicker i apologize,,, ive heard of people feeling the car to much and damaging the purge solenoid, i googled it to make sure but couldnt get a Defnent answer, but regardless i agree clear the codes and try it again, 100 bucks to just figure out what the problem is is retarded, try some fuel injector clearer ir octane booster! just tyr it and dont fill up ALL the waym when it click leave it alone dont round off to the dollar! keep me posted
Old 07-15-2010, 10:23 PM   #10
First I would invest in an SCT tuner, that has a built in diagnostic tool so you can read and clear codes in your driveway. If throttle body is one of the problems American Muscle has one from BBk, brand new throttle body, for I believe 269.00. Easy to install. As far as the other code goes not so sure. I agree with the others though, DO NOT GO TO DEALER YET, clear the codes and try it again...Good luck!
Camaro Eater is offline   Reply With Quote
Old 07-16-2010, 05:18 AM   #11
Zebs5408's Avatar
im gonna rule the throttle out on this one....but dont quote me lol...sonic where u at he usually chimes in on these....i still think it might have something to do with fuel delivery!
Old 07-16-2010, 10:44 AM   #12
Well i filled up yesterday, and it did not fail on me!! But i found out the dianostic check will be covered under warrenty, so i think ill do it anyway since i dont have to pay. BUt i do think its probaly something dumb like the gas cap not venting good. I really really appretiate all the help, and after i get th diagnostic i will let you guys know how it works out.
Old 07-17-2010, 07:26 AM   #13
Zebs5408's Avatar
OH SWEET YES UTILIZE EVEYRTHING WHILE ITS UNDER WARRANTY....if u have any problems or think anything might become a problem get it check while its under warranty,,,,i remember my warranty......its been so long...i miss her, i should have never let her go
Old 07-17-2010, 04:32 PM   #14
Send a message via AIM to VCS_SSSTANG
Correct me if i'm wrong, but isn't the 2005 v6 Drive By wire?
@blackbandit, yes if its under warranty buy all means take it in and let ford fix whatever is wrong before you get stuck with a bill later down the road. Let us know how it goes
VCS_SSSTANG is offline   Reply With Quote
Old 07-19-2010, 12:56 PM   #15
Thanks so much for the help you guys, i will have an awnser tomorrow after i take it to ford. Hopefully its nothing major, but my warrenty should cover it anyway . And i planned on getting a sct tunner before all this started happening anyway.
Old 07-19-2010, 01:08 PM   #16
100 I made it .. no longer a newb
zztop1234 is offline   Reply With Quote
Old 07-20-2010, 01:53 PM   #17
Zebs5408's Avatar
LOL bless ur heart
Battery/engine/oil leakeage problems? blackhawk Pre-2005 V6 Mustang 2 01-09-2010 05:50 AM
Engine noise from COLD engine 03GreyMach1 1996-2004 Mustang GT 10 03-14-2008 07:40 PM
engine swap 1989 to 1992 4 cyl engine dannyc1992 General Mustang Discussion 0 02-08-2008 01:59 PM
Engine Swap/ Engine Shakes too_cool_mitch Pre-2005 V6 Mustang 2 02-28-2006 02:01 PM
a/c problems Warfire80 1996-2004 Mustang GT 6 11-29-2004 04:52 PM
10:11 AM
