Do Octane boosters work???? - Mustang Evolution
Old 07-16-2010, 08:29 PM   #1
I have heard many many mixed reviews on this one...do octane boosters really work? If so how do thay work and which one is best??
Camaro Eater is offline   Reply With Quote
Old 07-16-2010, 08:52 PM   #2
hottcobra's Avatar
Re: Do Octane boosters work????
In a word no.
The only one that is any good it Lucas brand but it only bumps it up by one or two points.
Old 07-16-2010, 09:12 PM   #3
Send a message via Yahoo to DDavis30
Yup.. they work ... they clog fuel filters and foul spark plugs very quickly ...
When an octane booster says it can boost your fuel's octane by 4 - 5 points that just means your 93 octane fuel will be raised up to 93.5 at best.... Not worth it if ya ask me...
2004 V6 Mustang
2006 Pontiac Torrent
1990 Nissan 300zx
1999 Suzuki Intruder 1400
DDavis30 is offline   Reply With Quote
Old 07-17-2010, 09:50 AM   #4
There are 2 that I know of that work. Octanium and torco. But those aren't really boosters. Those are concentrated race gas.
Old 07-17-2010, 09:50 PM   #5
91sleeper's Avatar
waste of time and money. you will want the 10 mins of you life back that it took to go into then store and pour it in and the 10 bucks you spent. Dont understand why you woulld wanna run it anyways could someone tell me?
331stroked vortech 16psi
91sleeper is offline   Reply With Quote
Old 07-17-2010, 10:16 PM   #6
My thought is higher octane, higher SCT tune, better performance... does that make since? Or am I way off? I mean where Im at 91 octane is the highest octane you can buy at a gas station and ordering higher octane gas every time I need a fill up seems silly...I thought maybe this could be the answer...I was thinking Lucas, if that matters...any thoughts??
Old 07-17-2010, 10:30 PM   #7
91sleeper's Avatar
Nope theres not going to be enough performance difference to justify the cost. High octane is used for engines that have more timing, high compression, N2O, or boost. It keeps the engine from spark knocking or pinging how ever you want to say it.
The octane rating of gasoline tells you how much the fuel can be compressed before it spontaneously ignites. When gas ignites by compression rather than because of the spark from the spark plug, it causes knocking in the engine. Knocking can damage an engine, so it is not something you want to have happening. Lower-octane gas (like "regular" 87-octane gasoline) can handle the least amount of compression before igniting.
The compression ratio of your engine determines the octane rating of the gas you must use in the car. One way to increase the horsepower of an engine of a given displacement is to increase its compression ratio. So a "high-performance engine" has a higher compression ratio and requires higher-octane fuel. The advantage of a high compression ratio is that it gives your engine a higher horsepower rating for a given engine weight -- that is what makes the engine "high performance." The disadvantage is that the gasoline for your engine costs more.
Old 07-18-2010, 12:55 AM   #8
iwannagofast's Avatar
so with a 331 and 16psi what kind of numbers do you put down?
iwannagofast is offline   Reply With Quote
Old 07-18-2010, 09:05 AM   #9
91sleeper's Avatar
not going to tell my spot on numbers but rwhp and rwtq is well over 600
Old 07-19-2010, 08:33 PM   #10
rinfield2004's Avatar
nope. they change your octane by like .10 or a .010. Now, if you buy a whole case of them, maybe. :}
rinfield2004 is offline   Reply With Quote
Old 07-19-2010, 10:01 PM   #11
91sleeper's Avatar
cheaper to buy race fuel than octane booster
Old 07-20-2010, 07:31 AM   #12
They say Lucas works better than most, but dont rely on them at all as they wont do much of anything.
Old 07-20-2010, 08:02 AM   #13
Thank you all so much, I always appreciate all your help guys!!
Old 07-20-2010, 11:41 PM   #14
MonteCitan's Avatar
For what its worth, I've tried the off the shelf 91 octane tune from SCT in my rustang..
It had really bad spark knock on tip-in and in third gear at WOT it was audible..
A bottle of lucas completely cured it (half tank of 91)
Of course the proper way to do it would be tune it out.. Which I plan to do in a few weeks
But IMO if there's no spark knock, you don't need octane booster
2012 IS F Blue IS F Sport
2006 Mustang V6 wannabe
Old 07-21-2010, 12:38 AM   #15
Funny you mention the ping noise I do have that as well with the sct 91 tune, I will try Lucas purely for that reason thanks so much that's a big help!
Old 07-22-2010, 02:41 PM   #16
blue-saleen's Avatar
Region: Utah
Where are you? Every 7-11 I go to has 93 Octane
blue-saleen is offline   Reply With Quote
Old 07-22-2010, 02:56 PM   #17
He's in california...I believe 93 is very hard if not impossible to find out there....damn tree huggers.
Old 07-22-2010, 03:26 PM   #18
LMFAO! Yeah CA. And 93 isn't anywhere out here!!
Old 07-22-2010, 03:49 PM   #19
Region: Utah
Well that sucks.
Old 07-22-2010, 09:09 PM   #20
67mustang97's Avatar
Region: Vermont
We used to have 94 octane at Sunoco in Vermont. Back in the good old days.
Old 07-23-2010, 12:06 AM   #21
MonteCitan's Avatar
Impossible to find.. and the 91 octane we get is oxygenated.. It's lame as $!@*
But as mentioned before, my spark knock issues on the 91 octane tune vanished using lucas octane booster, not sure what that's worth..
87 vs 93 octane tune....... outlawfrog 1996-2004 Mustang GT 12 11-16-2009 07:52 PM
Octane booster 98StangGT 1996-2004 Mustang GT 6 09-10-2006 07:51 PM
What octane to use chamillionaire Pre-2005 V6 Mustang 8 03-27-2006 09:34 AM
fuel octane charkelly9 Pre-2005 V6 Mustang 5 03-21-2005 01:22 PM
ME vs a Car with Rocket boosters MusclesFromBrussels Pre-2005 V6 Mustang 15 11-18-2003 07:32 PM
06:30 PM
