v6 to v6... - Mustang Evolution
Old 07-18-2010, 03:31 AM   #1
v6 to v6...
It's nearly time for me to pull the motor from my parts car which is a 03 v6, I am driving a 00. I read prior to this that there will be a possible issue with putting the motor from the 03 into the 00 because the motor is newer and would have eletrical problems. Just trying to find out if what i read was correct anyone know?
I was told that this will not be an issue if i take the eletrical haress. when I pull the motor instead of cutting it.... but I'm not 100% sure on that so... lol advice ?
Black_Sunshine is offline   Reply With Quote
Old 07-18-2010, 06:04 AM   #2
Zebs5408's Avatar
Re: v6 to v6...
bro the 99-03 are the same engines and harnesses i do believe..i tried to search a difference and nothing came up...the last 6 months of the 04 were made into a 3.9 but before that to 99 are ALL 3.8 witht the same wiring...if u were going from a 94-98 to 00 it would be different slightlly but this should drop in! haynes manual will walk u through it my friend...we love pics bro so grab a camera
04' mustang 3.9 40th Anniversary Edition- (V2 Vortech Supercharger, 38# injectors, 3.73 gears w/ T-lok, Predator Diablo, Mac cold air intake, Port & polished upper AND lower intake manifold, Mac Long Tube Headers, Mac o/r H pipe, flowmasters, 2.5 flowmaster tips)
03' Mustang GT (20" Cobra R's, 40 series Flowmasters)
Zebs5408 is offline   Reply With Quote
Old 07-18-2010, 06:44 AM   #3
Re: v6 to v6...
alright well I'm more then sure I read about that issue on these fourms... I'll go threw and check and possible cite the issue.
http://www.mustangevolution.com/forum/t246200/
I found it ( turns out you actually commented on it also lol )
Old 07-18-2010, 09:22 AM   #4
91sleeper's Avatar
Re: v6 to v6...
Make sure the lower intakes are the same I just did a swap at my shop and the lower intake had Butterfly in the ports on the lower intake and the 1999 didnt. Just changed the lower intake and all was fine.
331stroked vortech 16psi
91sleeper is offline   Reply With Quote
Old 07-18-2010, 10:03 AM   #5
Send a message via AIM to VCS_SSSTANG
Re: v6 to v6...
Yep he will have to swap lower intakes from the 00 to the 03 motor.
VCS_SSSTANG is offline   Reply With Quote
Old 07-18-2010, 12:27 PM   #6
91sleeper's Avatar
Re: v6 to v6...
Its a engine, a motor is electric. LOL
Old 07-18-2010, 03:08 PM   #7
Zebs5408's Avatar
Re: v6 to v6...
wow i didnt know that bout the lower intake...haynes manual is your friend
Old 07-18-2010, 03:44 PM   #8
91sleeper's Avatar
Re: v6 to v6...
HAHAHA no manual called been there done that.
Old 07-18-2010, 05:52 PM   #9
Re: v6 to v6...
LOL @ the motor comment
And I've never owned a haynes manual....
Old 07-18-2010, 06:55 PM   #10
Re: v6 to v6...
Yep that's IMRC Ford used...
Old 07-18-2010, 07:40 PM   #11
Re: v6 to v6...
OK, so what I need to do is take the motor out of my car. then the motor out of the 03, put the 03's motor into my 00 mustang.. but put the lower intake from my 00 into the 03 motor? lol could someone please explain this? I'm just a bit confused, Maybe because I've not slept and have been taping off and paining my dash board this morning then went to route 66 in joliet IL and saw loads of mustangs.
good day it was indeed.
Old 07-18-2010, 09:04 PM   #12
91sleeper's Avatar
Re: v6 to v6...
Take the lower intake off of the 2000 engine and put it on the 2003 engine. Make sure you replace the upper and lower intake gaskets. Do not buy the two gaskets as a kit there almost $100 that way buy them separate there $54 that way. I can prove this as well.
Old 07-18-2010, 09:29 PM   #13
Re: v6 to v6...
Ok will do but sorry I'm a noob when it comes to this stuff I know some. but theres also i must learn so please bare with me, Why must the lower intake be put in the 03?
Old 07-18-2010, 09:33 PM   #14
91sleeper's Avatar
Re: v6 to v6...
It has butterflies in the lower intake that the ECU controls. Your 2000 doesnt have the connections for this.
Old 07-18-2010, 09:40 PM   #15
Re: v6 to v6...
If the 03 motor works in the 03 w.o a problem how it is why wouldnt it work the same way in my 00? lol sorry once again... I think i'm gonna invest in a haynes or chilton manual... haha
Old 07-18-2010, 09:50 PM   #16
91sleeper's Avatar
Re: v6 to v6...
I explained it the only way I know how in post #14
Old 07-19-2010, 11:39 AM   #17
Re: v6 to v6...
Ok i finally get it ( now that i've had some sleep ) lol I was very tired last night, but anyways more or less i should just make sure that the lower intakes are the same and if there not I swap them correct?
Old 07-19-2010, 12:44 PM   #18
Re: v6 to v6...
four
zztop1234 is offline   Reply With Quote
04:10 AM
