2000 V6 clutch/shifting issue - Mustang Evolution
Old 07-18-2010, 08:01 PM   #1
Hey all. I'm mechanically pretty adept, do all of the work on my Mustang. At 60k, replaced the clutch plate, disc, etc as I was having rough shifts. The car is now 108k. Having just done my diff & trans fluids, the car is hard tough to shift. The gears were always a little rough, but now the problem has worsened. Currently:
Intermittent grinding from 4-5.
Consistent grinding from 1-2 @3500+ rpm. (if I allow the clutch more time, it will not grind 1-2)
During the winter, could not get from N-R unless car was warmed up, 20mins.
Cable is near the bottommost tooth on the quad, seems to have some slack. Do not believe there's any preload whatsoever. I did adjust cable closer to final tooth, only changed peddle position: did not help with gear grinding.
Also of note, having a helper push the pedal to the floor, I can still push the release lever further beneath the car. Again, is this cable stretched and it's not completely disengaging the clutch?
Thus, do "we" think it's a clutch cable replacement, or something with the trans?
audio75 is offline   Reply With Quote
Old 07-18-2010, 10:02 PM   #2
91sleeper's Avatar
Re: 2000 V6 clutch/shifting issue
what fluid did you use?
331stroked vortech 16psi
91sleeper is offline   Reply With Quote
Old 07-18-2010, 10:50 PM   #3
Trans? Ford factory fluid, ATF I believe? (Strange they use ATF in a Manual, but anyhow...)
Rear dif? Mobil1 90W gear oil, always have.
Old 07-18-2010, 10:59 PM   #4
91sleeper's Avatar
What trans come in those cars?
Almost sounds like its low on fluid.
Old 07-18-2010, 11:05 PM   #5
T45, I believe. I tried Redline back at 60k, had the worst shifting ever. Went back to Ford OEM in the same week. Filled it then (and now) until it spills from the fill plug, would believe it's as full as it's supposed to be. Shifting has always been rough, just not as rough as it is now.
Old 07-18-2010, 11:20 PM   #6
91sleeper's Avatar
Do your self a favor and go ahead and get yourself a Clutch Quadrant and a firewall adjuster. You will thank me.
Aluminum Clutch Quadrant, 1982-04 [MMCL-6] : Maximum Motorsports, the Latemodel Mustang Performance Suspension Leader!
Clutch Cable Firewall Adjuster, 1982-2004 [MMCL-3] : Maximum Motorsports, the Latemodel Mustang Performance Suspension Leader!
MM Clutch Cable, Universal Ford OEM, 1982-04 [MMCL-11] : Maximum Motorsports, the Latemodel Mustang Performance Suspension Leader!
American Muscle have there brand in a kit for around $100.
Old 07-18-2010, 11:29 PM   #7
I wondered if the quadrant was the issue, and/or the cable. The quadrant appears intact, but I believe the cable has slacked itself out. I've been reading about the aftermarket quad & firewall adjusters, and wondered what their gain was? Do they give faster depression of the plate allowing faster shifts?
Old 07-18-2010, 11:34 PM   #8
91sleeper's Avatar
My friend the stock quad sucks you will feel a world of difference and will wanna buy me a beer after the swap
Old 07-18-2010, 11:38 PM   #9
feel a difference in what area specifically? Is the shift smoother? Less resistance in the clutch pedal? If it's the key to my shifting issue, I'm sold. I don't at this point know if it's the synchronizers or the clutch cable, or what.
Old 07-18-2010, 11:41 PM   #10
91sleeper's Avatar
Pedal will feel much more solid and the firewall adjuster will fine tune the cable.
Old 08-01-2010, 12:41 AM   #11
Transmission shop diagnosed the issue: syncros and bearings. Work completed, took the car home, $1100 poorer.
(Moderators can close this topic, thank you)
4th to 5th shifting issue and hard as hell get into R - Black_Sunshine Pre-2005 V6 Mustang 7 03-18-2010 10:55 AM
Clutch smell issue Rich_Guy 1996-2004 Mustang GT 7 07-14-2009 10:56 PM
shifting problema 95stang_man Pre-2005 V6 Mustang 3 07-29-2005 12:37 AM
clutch issue for the 56# time lol SpectorV Pre-2005 V6 Mustang 1 05-12-2003 08:00 PM
07:30 AM
