shifting into gear, axle noise - Mustang Evolution
Old 07-18-2010, 07:18 PM   #1
When I go into any gear, stopped at an intersection, I hear a thud in the rear axle. During seal replacement at PassRear wheel, noticed play in side gear/pinion shaft/pinion gears to each axle.
Would replacement of these gears relieve this clunk/thud noise?
Would replacement of these gears then cause another issue requiring the ring/pinion to be replaced because they're no longer all evenly wearing together?
audio75 is offline   Reply With Quote
Old 07-18-2010, 09:00 PM   #2
91sleeper's Avatar
Re: shifting into gear, axle noise
Have you checked you Ujoint?
331stroked vortech 16psi
91sleeper is offline   Reply With Quote
Old 07-18-2010, 10:02 PM   #3
Cursory glance didn't indicate any leaking, no. When I replaced the clutch at 60k, I did mismark the U-joint relation to the drivetrain. Making a best guess, I thought I'd reconnected them properly. It is possible that I did not however.
If you believe that's my culprit, I would entertain it. So, either I just put up with it, or have the joint replaced?
Old 07-18-2010, 10:08 PM   #4
91sleeper's Avatar
U-joint leaking? No reason it would. Put the car on jack stands and put the car into a gear. Twist you driveshaft and see if you can head the noise. Also rock the wheels back and forth and see if you can hear it as well. Dont just replace parts till its fixed thats wasting money. Pin point the problem and fix it. Also while you are under there look at the transmission mount as well.
Old 07-18-2010, 10:16 PM   #5
Oh yes it's definitely the play in the side & pinion gears. Rocking the axle pinpoints is precisely. Obviously those parts have all worn simultaneously, so my question was that if I replace just those (omitting the ring&pinion and gear) would the problem be resolved? Or would the slack/gap just move to the gear or ring&pinion?
Old 07-18-2010, 10:23 PM   #6
91sleeper's Avatar
what side gear are you refering too
Old 07-18-2010, 10:27 PM   #7
Ford actually calls it a "side gear". It's in the differential case assembly. These side gears are visually a top/bottom gear, with holes in the center for the pinion shaft. Those gears have some slack/play when you manipulate the axles. I believe it's that play which I'm hearing while driving the car. It'd be "nice" to get rid of it, but not required.
Oh, and these side gears then connect to the gears for each wheel's axle.
Old 07-18-2010, 10:37 PM   #8
91sleeper's Avatar
I am with you now.I have always called them spider gears.
Old 07-18-2010, 11:05 PM   #9
Yes. Those four inner gears. My post is aimed at asking if replacing them would:
1) Resolve the clunk/thunk noise from the rear axle
2) NOT cause the issue to move to either the drive gear, nor the ring&pinion
Old 07-18-2010, 11:08 PM   #10
91sleeper's Avatar
I would check the trans mount and the U-joint first.
Cluthchless Shifting 2000StangLover Mustang Audio & Video 15 10-28-2008 03:44 PM
Clicking Noise kind of Squeeky Noise... braumab 2005-2010 Mustang GT 23 06-29-2008 11:24 PM
Gear and axle swap questions. DarkShadow Pre-2005 V6 Mustang 15 09-07-2005 02:18 AM
auto/manual tranny gear and rear gear STOCK ratios SpectorV Pre-2005 V6 Mustang 0 07-08-2004 02:41 PM
09:11 PM
