swapping a 96 mustang 3.8 with a 2002 3.8 - Mustang Evolution
Old 07-20-2010, 09:29 AM   #1
we have done the swap but the 02 engine is running rich and bogging down
Do we need to change the pcm out or have it reprogrammed for the 02 engine
are there any other issues we should check?
It runs worse with the front o2 sensors plugged in
I am going crazy at this time with this car
deerslazer is offline   Reply With Quote
Old 07-20-2010, 02:12 PM   #2
Zebs5408's Avatar
Re: swapping a 96 mustang 3.8 with a 2002 3.8
BREATHEEEEEEEEEEEEEEE........haynes manual is your friend, start from the beginning, what all are u using from the 96 with this 02 engine?
04' mustang 3.9 40th Anniversary Edition- (V2 Vortech Supercharger, 38# injectors, 3.73 gears w/ T-lok, Predator Diablo, Mac cold air intake, Port & polished upper AND lower intake manifold, Mac Long Tube Headers, Mac o/r H pipe, flowmasters, 2.5 flowmaster tips)
03' Mustang GT (20" Cobra R's, 40 series Flowmasters)
Zebs5408 is offline   Reply With Quote
Old 07-22-2010, 09:24 AM   #3
Right now nothing. Thinking about putting 96 intake,wiring harness, and injectors on engine
Can't find answer from anyone if this will work or not
Will single port intake even fit the 2002 motor?
Old 07-22-2010, 09:46 AM   #4
Herbstang's Avatar
Why would you want to do that ?? you'd would be better off getting the PCM from the 2002 also you now have 21 injectors the 96 had 14
Old 07-22-2010, 10:16 AM   #5
Send a message via AIM to VCS_SSSTANG
You need some sort of tune, or its not going to run right and you could result in engine damage. A haynes manual would do you no good here, but if you did the swap i'm sure you know that...
Also, since its an 02 engine, did you delete the IMRC's in the lower inake?
VCS_SSSTANG is offline   Reply With Quote
Old 07-22-2010, 11:33 AM   #6
91sleeper's Avatar
Might just need to put the old injectors back in it and see how that runs.
331stroked vortech 16psi
91sleeper is offline   Reply With Quote
Old 07-22-2010, 01:03 PM   #7
That should help it a bit, but its still gonna need a bit of tuning
swapping a C5 505danielm Pre-2005 V6 Mustang 2 01-05-2009 12:28 PM
swapping the rear from the 90 into the 64? fast64 Classic Mustangs 8 04-27-2006 10:13 PM
How-to: Swapping a late model, EFI 5.0 and a t-5 into your classic Mustang fast64 1979-1995 Mustang GT 8 05-29-2005 04:15 PM
Swapping brakes Rellik Pre-2005 V6 Mustang 11 10-16-2003 07:06 PM
12:40 AM
