Instrument cluster swap - Mustang Evolution
Old 07-21-2010, 07:52 PM   #1
ponyboy94's Avatar
Exclamation Instrument cluster swap
Will a 99-04 mustang gt instrumment cluster fit and work on my 02 mustang v6 if not what do I have to do to change my instrument cluster?
ponyboy94 is offline   Reply With Quote
Old 07-22-2010, 12:07 AM   #2
upton7's Avatar
Re: Instrument cluster swap
Well the speedometer on the gt reads higher and I think the harness might be different but if you get one from a v6 it will work no problem they aren't hard to swap at all.
Old 07-22-2010, 07:48 AM   #3
Send a message via AIM to VCS_SSSTANG
Yep, never done the swap personally but I know it works.. You have to find someone @ ford who will calibrate it for you also.
VCS_SSSTANG is offline   Reply With Quote
Old 09-10-2010, 06:59 AM   #4
ponyboy94's Avatar
thanks alot ill let you know how it goes
Old 09-10-2010, 07:05 AM   #5
its far more hassle than its worth, plus the speed is harder to read in a GT
Old 09-10-2010, 08:48 PM   #6
1ijack's Avatar
Send a message via Yahoo to 1ijack
it is not the speed i would worry about but the RPM gauge, I have notice that redline for the 3 different models are different. I was going to change mine but i can't find the redline with 5750 redline. Simco had one but the speedo was right but the rpm are higher.
I looked at overlays and they are the same one or the other is higher...
The Mustang Mafia
"Join the family, if you dare"
www.themustangmafia.com
1ijack is offline   Reply With Quote
Old 09-13-2010, 08:43 AM   #7
why does the painted redline on the gauge cluster have to be higher though? redline is not where peak power is made by the way
Old 09-13-2010, 09:48 AM   #8
1ijack's Avatar
i don't know it is just where they sit for the different models i asume
The Mustang Mafia
Old 09-13-2010, 09:57 AM   #9
oh sorry, i was confused. It is an issue, for example my 01 v6 had redline different than the previous but ford didnt change it
Old 09-13-2010, 11:54 AM   #10
02Nate281's Avatar
Send a message via AIM to 02Nate281 Send a message via MSN to 02Nate281 Send a message via Yahoo to 02Nate281 Send a message via Skype™ to 02Nate281
You can get them from ebay for $40-60 on average. Trust me I know. It really doesnt matter where the redline on the gauge is. Your car won't rev that high anyway, it will just bounce off the limiter at peak rpm's. The limiter is around 6200 for GT's and around 5700-5800 for V6's.
"There is no love without sacrifice"
02Nate281 is offline   Reply With Quote
Old 09-16-2010, 09:43 PM   #11
ponyboy94's Avatar
Ok so I tried to swap the gt cluster with my v6 cluster and it fit the first problem I ran into was the theft system with the keys I was unable to surpass that if anyone can get past that please let me know how and if you are jus gunna try it for fun it's a waste of time it took me 3 hours to try several ideas and they all failed
Old 09-16-2010, 09:47 PM   #12
02Nate281's Avatar
The curcuit board is programmed to the car it was originally installed in. You need to go to a ford dealership and have it reprogrammed to your car. I have the same issue with a cluster from an '04 GT I just bought off ebay. It fits and the gauges read properly but it isn't programmed to work with my car.
Old 09-16-2010, 11:01 PM   #13
The real question is can you make a 99-00 instrument cluster work in a 94-95????? I might have to try.
Straublittleman is offline   Reply With Quote
Old 09-16-2010, 11:03 PM   #14
02Nate281's Avatar
google pics of those clusters. if they have the same plug ports, then yes.
Old 09-16-2010, 11:08 PM   #15
A friend of mine has a junk yard and he has a green 00 mustang v6 in it. It has a white faced gauge cluster in it, some one must have ordered it that way? because it only has 38,xxx miles on it. Was wrecked but the air bags are good I'm getting the interior out of it.
Old 09-16-2010, 11:12 PM   #16
1ijack's Avatar
unless you have the car programmed from stock when you use a SCT programmer it takes the rev limiter off.
The Mustang Mafia
Old 09-26-2010, 07:18 PM   #17
Keep in mind that the 94-98 clusters had the analog tooth gear driven odometers. The 99+ cars had digital readouts. Not sure if the wiring will work or if the computer will accept the new cluster...it might, I honestly don't know.
Old 09-28-2010, 06:09 AM   #18
ponyboy94's Avatar
i tried programming my keys to the new cluster and that didnt work either
instrument cluster gages dd96stang Pre-2005 V6 Mustang 3 08-02-2010 08:47 AM
Brake, ABS & Instrument Cluster stevinas 2005-2010 Mustang GT 4 07-01-2008 08:53 AM
Need help on Instrument cluster. Batroo 1979-1995 Mustang GT 4 04-23-2008 09:48 PM
instrument cluster swap pipeguy General Mustang Discussion 0 04-11-2008 09:43 AM
94 - 95 GT Instrument Cluster StreetRacer4371 Mustang Parts for Sale and Wanted 5 10-21-2004 08:32 PM
01:36 AM
