2000 v6 misfire - Mustang Evolution
Old 07-23-2010, 03:51 PM   #1
shelby00's Avatar
2000 v6 misfire
My service engine light cam on and i had it checked. It said misfire cyl 6. So i had the plugs and wires changed. Then the light came back on and said misfire cyl 1. I had the coil pack, and fuel filter changed. Even had the plugs checked again, and they are good. The miss is only between 1000-1500 rpms. Do yall have any ideas of what it could be?
The car only has 104k miles.
2000 v6- stock
shelby00 is offline   Reply With Quote
Old 07-23-2010, 04:56 PM   #2
Zebs5408's Avatar
Re: 2000 v6 misfire
Spark plug loose or there out of seqeuence
04' mustang 3.9 40th Anniversary Edition- (V2 Vortech Supercharger, 38# injectors, 3.73 gears w/ T-lok, Predator Diablo, Mac cold air intake, Port & polished upper AND lower intake manifold, Mac Long Tube Headers, Mac o/r H pipe, flowmasters, 2.5 flowmaster tips)
03' Mustang GT (20" Cobra R's, 40 series Flowmasters)
Zebs5408 is offline   Reply With Quote
Old 07-23-2010, 06:23 PM   #3
shelby00's Avatar
Re: 2000 v6 misfire
They arent loose, i had them checked. If they were out of sequence wouldnt the car run bad all the time instead of only between 1000-1500 rpms?
2000 v6- stock
Old 07-23-2010, 09:06 PM   #4
Zebs5408's Avatar
Re: 2000 v6 misfire
are you driving it while it misfires? the guess was because i had a firebird that did the samething in the same RPM range, i stuck my hand down there and the plug was loose, i pushed it in and problem stopped! bro i wish i was there to see it for myself, u changed coil pack and everything else so idk, unless the problem is deeper.......have we checked the Fuel injectors?
Old 07-23-2010, 09:52 PM   #5
shelby00's Avatar
Re: 2000 v6 misfire
Im driving it when it has the misfire. My husband cant even figure it out becuz we done changed everything, he even checked the injectors. We just wanted some more opinions on it. Anyways we are getting an compression test done tomorrow so maybe that will help us figure something out hopefully.
2000 v6- stock
Old 07-23-2010, 11:34 PM   #6
Zebs5408's Avatar
Re: 2000 v6 misfire
Awesome cause im stuck...and seeing how theres almost 20 veiws and not one except me has commented no else knows either lol
Old 07-24-2010, 10:53 PM   #7
91sleeper's Avatar
Re: 2000 v6 misfire
Unplug the MAF and see how it drives. It might not idle but drive it and see what happends. There is also a crankshaft sensor on there cars that tells the car when to fire. Compression should not be a factor with your issue. If you had low compression then you would be getting blow by and would have oil smoke coming out of you exhaust pipe.
331stroked vortech 16psi
91sleeper is offline   Reply With Quote
Old 07-26-2010, 03:05 PM   #8
shelby00's Avatar
Re: 2000 v6 misfire
[QUOTE=91sleeper;757749]Unplug the MAF and see how it drives. It might not idle but drive it and see what happends. There is also a crankshaft sensor on there cars that tells the car when to fire. Compression should not be a factor with your issue. If you had low compression then you would be getting blow by and would have oil smoke coming out of you exhaust pipe.[/QUO
I will try unplugging the MAF and see what it does.
2000 v6- stock
Old 07-29-2010, 04:00 PM   #9
racefan966's Avatar
Region: Idaho
Re: 2000 v6 misfire
What wires are you using? If they are do not have a EMI (Electro Magnetic Interfience) sheilding they will mess with the cam sensor making it miss.
racefan966 is offline   Reply With Quote
03 GT Misfire finallyaGT 1996-2004 Mustang GT 7 08-26-2009 01:11 PM
Another misfire 2000MustangGT17 1996-2004 Mustang GT 5 06-24-2009 08:47 AM
#1 misfire 2kslvrgt 1996-2004 Mustang GT 4 02-17-2009 01:26 PM
another misfire! Jeremym831 1996-2004 Mustang GT 4 03-03-2008 10:01 AM
misfire in #1 vramos1 Pre-2005 V6 Mustang 4 09-15-2007 02:24 PM
11:58 PM
