Need an answer asap... removing interior part - Mustang Evolution
Old 07-25-2010, 01:09 PM   #1
Ok so today is my last free day untill next weekend I've been painting the interior of my mustang - I've got the torx tools needed to pop off the seat belts and such but I cant figure out how you remove the rear quater panel window thing on either sides of the car... I un did all the bolts for it - with the torx but still can figure this out... lol... help?
also rear seat - top and bottom part - how do you remove those?
thanks guys. once again
Black_Sunshine is offline   Reply With Quote
Old 07-25-2010, 01:13 PM   #2
jimmy_beaner's Avatar
Region: Iowa
Re: Need an answer asap... removing interior part
If memory serves, you undo the seat belt and pop off the plastic piece. Then there are 4 attachment points you undo to remove the c-pillar (though I also believe you'll have to remove some of the a-pillar connections). That will allow you access to the window.
Old 07-25-2010, 01:32 PM   #3
I already have the plastic peice off thats not the problem. the problem that i'm having is the seat belts go threw this peice in the front. do i just disconnect the torx bolt thats on the floor then feed that threw the seat belt hole of the plastic peice?
Old 07-25-2010, 01:37 PM   #4
Region: Iowa
you could... if you're just getting to the window you shouldn't have to. I just left the belt through it and moved it out of the way (onto the back decklid)
Old 07-25-2010, 04:55 PM   #5
I'm just trying to remove the rear seat belts so i can paint that plastic bezel around the window, lol the seat belt is in the way. I removed the lower part of the rear seat, and well. I found the torx bolts but had an issue getting them to twist... there stuck in there so I've got no clue how i'm going to get this done. garhg.
Old 07-25-2010, 05:03 PM   #6
Region: Iowa
ohhhh, you mean the REAR seat belts
Old 07-25-2010, 07:15 PM   #7
yes. I've figured out where the torx bolt goes in to remove it.. but it will not turn... wd40... rescue me.. hah.
Old 07-27-2010, 03:32 PM   #8
runvsofthisbull's Avatar
Not sure if this helps, but I know the Hanes manual was helpful for me when I installed new speakers on my 2002 convertible. I had to remove the rear seat to acesse similar panels.
2002 True Blue V6 to GT Vert
16.1@86 as an auto 3.8
Old 08-03-2010, 06:09 AM   #9
Tape's Avatar
you need to remove the seats before the panel will come off, sorry but too much for me to type at the moment.
Tape is offline   Reply With Quote
need answer bobbyoooo 1996-2004 Mustang GT 11 12-18-2008 12:26 PM
Answer a ?/Ask a ? topless67 The Bar 490 07-18-2007 09:08 PM
Pics of my interior (painted interior warning!!!) WhiteStang99 Pictures and Videos 25 03-02-2005 11:12 PM
Someone answer this?? Jayber The Bar 6 02-16-2004 11:43 PM
10:18 AM
