Crush sleeve?!?! - Mustang Evolution
Old 07-30-2010, 09:43 AM   #1
Crush sleeve?!?!
So I replaced the pinion seal in my rearend a few weeks ago. Now when I change from first to reverse or vise versa, and start moving i hear a huge clunk from the rearend. Oh yeah, also when i slam it into second too hard too. Could that possibly be the gears slipping?! how do i fix this?!!? Any help would be greatly appreciated.
pringle9666 is offline   Reply With Quote
Old 07-30-2010, 03:47 PM   #2
67mustang97's Avatar
Region: Vermont
Re: Crush sleeve?!?!
Did you check your U-Joints?
Old 07-30-2010, 04:45 PM   #3
yes actually i put it up on jack stands to hear or see where its coming from, thats them! lol Thank you! And now there is a howling noise when i drive.... it was realllly loud mostly when im on the gas, and would settle down a little bit when i let off but still do it... i put more gear oil in the rearend and checked my right rear brake. the piston on the caliper froze up so it was grinding like crazy.. so i fixed the brake and along with adding gear oil i test drove it and the howl quietted down quite a bit but its still there... keep in mind the sh** i did with the pinion nut... Any clues as to what that howl is?!?!
Im about to just sell it and buy a foxbody 5.0
Old 07-30-2010, 06:24 PM   #4
Region: Vermont
If your rear end is howling It could be a couple of things. It may be a wheel bearing or your gears. If the noise came after playing with your gears that's what I would expect. How bad is it? Usually once a gear howls you'll have to live with it or replace the gears. You could try to tighten up the pinion nut a little to see if it quiets down. I wouldn't drive it much till you looked at it again. Good luck
Old 07-30-2010, 09:42 PM   #5
ponyboy94's Avatar
I would have it checked sounds like it's not shimmed right.
ponyboy94 is offline   Reply With Quote
Old 08-03-2010, 05:57 AM   #6
Tape's Avatar
is this your first gear change? did you have the correct tools to check runout and shim it correctly, what was your runout and what did you shim it to, sound like you need to redo or a recheck at the least. It's not a remove and reinstall like a wheel.
Tape is offline   Reply With Quote
Old 08-03-2010, 07:41 PM   #7
I didnt do a gear change i just changed the pinion seal.anyways the clunking was the driveshaft taht worked its way loose, and ghe howling was the new brakes with the old rusted bracket so the sleeves wouldnt move freely.. thanks guys!
La County law says you race, we crush your cars Seph The Bar 19 10-18-2004 12:01 AM
» Members Mustangs
150
dimo
SHADOW
SHADOW
Add your Mustang
08:33 AM
