After 39,000 trouble free miles It died - Mustang Evolution
Old 07-30-2010, 06:46 PM   #1
Herbstang's Avatar
Just got done eating at the local country buffet Started the car just fine drove thru the parking lot, turn on the main road and it DIED !!!! push the car in a parking lot lifted the hood and had Denise crank it over ,it tried to start but was coughing and spurrting then I notice the under drive pully wiggling !!!!!
Called a buddy up said HELP we check all the bolts they we're tight took off the pulley and belt .crank it some more Looks no oil leaks like I 'll have to replace the harmonic balancer and hope to hell the crank isn't ****ed Any input is welcomed
Old 07-31-2010, 12:22 PM   #2
Re: After 39,000 trouble free miles It died
I haven't any idea what that would be. Anyone else have any input?
Old 07-31-2010, 12:55 PM   #3
Herbstang's Avatar
It's alive !!!! It was exactly what I was told it would be !!! The balancer crack at the neck thankfully the crank wasn't damaged .
Had to replace ithe 25% UDP with a stock one and up course my stock one got lost in the last move
So i spent 112.00 for the balancer 46.00 new belt at the stealership and 1.5 hrs of my time would of been quicker with some air tools and a few less smoke breaks took it out for a ride and all is good
Old 07-31-2010, 01:23 PM   #4
Glad it was a relatively cheap fix
Old 07-31-2010, 01:58 PM   #5
hottcobra's Avatar
Good to here it wasn't the crank.
Old 07-31-2010, 06:00 PM   #6
Tape's Avatar
herb, was it a piggyback?
Tape is offline   Reply With Quote
Old 08-01-2010, 05:55 AM   #7
Herbstang's Avatar
If by piggyback you mean a 2 piece pullie ( UDP pully bolts up to UDP suppiled balancer) setup then yes !!
I'm gonna try and contact VMP Tuning (who I purchased from 7 years ago) or one of the site sponsors to see if i can get just the balancer and then reinstall the UDP
But I can't truthfully say I noticed any lost of power going back to stock and doing the install in a carport is a pain in the *** !!! The hardest part turned out to be getting the belt tentsioner to cooperate
Old 08-01-2010, 08:34 AM   #8
Good news!!!
zztop1234 is offline   Reply With Quote
Old 08-01-2010, 10:06 AM   #9
Tape's Avatar
herb, you do know you can't use the same belt if your using the factory pulley?
Old 08-01-2010, 10:12 AM   #10
Herbstang's Avatar
Originally Posted by zztop1234 View Post
Good news!!!
Yeah !! Kinda of funny feeling relief when a part from your motor falls off in 3 pieces. I knew then the crank wasn't twisted .I checked for any metal damage to the front of the crank all looked good keyway wasn't damaged So I'm very happy
Old 08-01-2010, 10:15 AM   #11
Herbstang's Avatar
I bought a new factory belt 46.00 But thanks for thinking about that
Old 08-01-2010, 06:31 PM   #12
if its aftermarket pulley/balancer wise it may have just worked itself out as it takes a ton of tq to put it on, and might take a while to work loose, either way it does NOT take much in terms of movment for the computer to trip a CEL misfire code if the balancer is loose, so you cant have drove it loose for long, hopefully its ok.
Old 08-06-2010, 01:01 PM   #13
runvsofthisbull's Avatar
How much was the stock pulley? I have
mine in the garage. Just needed to call.
2002 True Blue V6 to GT Vert
16.1@86 as an auto 3.8
2008 GT with only 8 miles for 13,000 Brent Pictures and Videos 11 06-24-2008 09:18 AM
Rare 01 Bullitt True Blue(only 22,000 miles) casperpony Mustangs for Sale and Wanted 5 03-11-2008 07:17 AM
My Chrysler 300 M, almost 124,000 miles... Rick0636 Pictures and Videos 15 11-26-2005 11:31 PM
05:46 AM
