Clutch frustration - Mustang Evolution
Old 08-01-2010, 08:44 PM   #1
blue-saleen's Avatar
Region: Utah
Clutch frustration
Does anyone else have a clutch pedal that sits higher than their brake pedal? I hate it. I was hoping the clutch kit from AM would help lower it, but it didn't. Is there any way I can make it even with the break pedal, or maybe even lower? Also, how should I have the kit set? Currently the clutch engages after I let off the pedal about half way.
blue-saleen is offline   Reply With Quote
Old 08-02-2010, 08:23 AM   #2
1996v6stang's Avatar
Re: Clutch frustration
yeah my clutch pedal sits higher than my brake pedal too and i hate it.
1996v6stang is offline   Reply With Quote
Old 08-02-2010, 08:46 AM   #3
MM makes a petal hight adjustment kit, thats what you are looking for, the clutch cable doesnt effect (not usually) the bump stop the clutch petal sits on, thats why its so high. But... you dont want a clutch petal thats to low so you dont get full extension when using it~ probably not an issue just FYI.
Old 08-04-2010, 12:02 PM   #4
Tape's Avatar
mine are about even, maybe it's pre-new edge cars???
Tape is offline   Reply With Quote
Old 08-04-2010, 12:33 PM   #5
That is ford's design to make it happen. Right now, mine is just barely higher than my brake pedal because I installed the MM clutch height adjuster thing. I have mine set at the highest setting at the moment while I found the perfect setting for the firewall adjuster. Now, I will lower the pedal down as far as I can until I don't get the full release of the clutch or I bottom out the adjuster...whichever happens first.
What quadrant to you currently have in your car? And do you have a firewall adjuster? And when you say MM clutch kit, are you referring to the like $15 pedal height adjuster?
Old 08-04-2010, 07:35 PM   #6
Region: Utah
Hey Purevenom, I don't know if you are talking to me or Spec but if you are to me, I have the quadrant and firewall adjuster from AM
clutch help guerrerosal Pre-2005 V6 Mustang 4 03-22-2009 11:19 AM
need a clutch and... DarkShadows 1996-2004 Mustang GT 12 01-02-2009 11:54 AM
5 speed frustration 1quikV6 Pre-2005 V6 Mustang 26 11-06-2006 02:54 PM
clutch help mtchll50 1979-1995 Mustang GT 9 09-10-2006 07:09 AM
New clutch electricstang Pre-2005 V6 Mustang 2 05-22-2006 03:04 PM
02:31 PM
