instrument cluster gages - Mustang Evolution
Old 08-02-2010, 06:18 AM   #1
I changed the gage background in my 96 mustang to the white gages and it looks very kewl, however after 4 tries, I still cannot get the fuel gage needle to hold the position I set it in while apart. Last try I had it where I knew it should be, left it sit for 30 minutes before I put the cover back on and re-installed making sure it did not move. As soon as I turn the key the gage drops 1/4 tank.
Anyone else experience this? What am I missing? All other gages are fine
dd96stang is offline   Reply With Quote
Old 08-02-2010, 07:18 AM   #2
Re: instrument cluster gages
fill the car up 100% crank the car, then put the needle on at a touch past F, thats the best you can do after you take the needle off other than taking apart the dash and finding the wires and figuring out what signal equals what amount of gas and such
Old 08-02-2010, 07:47 AM   #3
thanks SpectoV Just filled up this morning. Guess what I'll be doing after work....... Thanks again
Old 08-02-2010, 08:47 AM   #4
when you press the needle down make SURE you dont push it down to far (or not far enough) else it wont turn or fall off
Instrument cluster swap ponyboy94 Pre-2005 V6 Mustang 17 09-28-2010 06:09 AM
Brake, ABS & Instrument Cluster stevinas 2005-2010 Mustang GT 4 07-01-2008 08:53 AM
Need help on Instrument cluster. Batroo 1979-1995 Mustang GT 4 04-23-2008 09:48 PM
instrument cluster swap pipeguy General Mustang Discussion 0 04-11-2008 09:43 AM
94 - 95 GT Instrument Cluster StreetRacer4371 Mustang Parts for Sale and Wanted 5 10-21-2004 08:32 PM
11:46 PM
