Exhaust - Mustang Evolution
Old 08-02-2010, 02:20 PM   #1
obxdude018's Avatar
Exhaust
Ok I don't have special privileges yet, but I need to get a driver side over the axle exhaust pipe. Also, what will be needed to make the switch to dual exhaust, I have a o/r h-pipe, I will need the over the axle pipe and muffler and hangar brackets and clamps, is there anything else im missing.
Thanks
obxdude018 is offline   Reply With Quote
Old 08-03-2010, 05:45 AM   #2
Tape's Avatar
Re: Exhaust
if you car is a gt then all you need is 2 mufflers
Tape is offline   Reply With Quote
Old 08-03-2010, 05:49 AM   #3
obxdude018's Avatar
Re: Exhaust
Umm.. No it's not hence the switch to dual exhaust.
Old 08-03-2010, 06:12 AM   #4
Tape's Avatar
Re: Exhaust
sorry, missed that, the thing to do is find someone doing a header swap with dumps.
Old 08-03-2010, 07:16 AM   #5
Re: Exhaust
when I had mine done I had a shop cut where the two pipes come together (before that point enough to put two new pipes in) then run a new pipe on each side back to where a GT muffler sits (you will need a hanger to hang the muffler on the passenger side) then I had them fab up the over the axle part~
You can buy a GT take off exhaust and have a shop fab up the connection~ or you can buy a dual exhaust adapter pipe then just install it and bolt up any GT catback you want.
Old 08-05-2010, 06:35 AM   #6
obxdude018's Avatar
Re: Exhaust
Ok as I wait for about 5 different packages to arrive, what will be some issues that I will occur when I make the switch to dual exhaust, I will be going with a pypes off-road h-pipe, gt over axle pipes to flow 40's with 3.5" tips. I know I have to remove the cats will the h-pipe clamp right to the stock headers, will I have to relocate the o2 sensors. I'm not worried about the bumper I have a dremel kit and the tools to make a nice cut. Just want some info for a smooth install.
Coming soon
Dual Exhaust
___________
'05 Torch Red - Dual Stripes, 5 spd Manual, 93 Octane Tune & CAI, FRPP T-loc, Motive 4.10 gears, FRPP Shocks and Struts, FRPP 1.5" Springs, BMR Adj. Panhard Bar, UMI Adj. UCA, J&M Extreme LCA, FRPP Tower Brace, Sequentials, 1/4 window louvers, Door Scoops, Train Horn
Old 08-05-2010, 08:43 AM   #7
runvsofthisbull's Avatar
Re: Exhaust
Not sure of the 05 and up, but when I replaced my stock H pipe/y-pipe (which unbolted at the headers) the cats came off because they are attached to the stock Y-pipe, thus there was no need to remove cats seperately. The pipes off road H-pipe will have to have the 02 sensors installed, however you may need a 02 sensor extensions (basically just longer cables to reach the sensors). I don't necessarily think you will have to relocate the sensors in a different position, however they will have to be installed into the new H-pipe. Not sure if this helped, but good luck.
2002 True Blue V6 to GT Vert
16.1@86 as an auto 3.8
exhaust
04:28 PM
