check engine trick - Mustang Evolution
Old 01-09-2007, 03:48 PM   #1
check engine trick
what is the trick to turn off that light, is something whith the battery but im not sure
carlosc is offline   Reply With Quote
Old 01-09-2007, 04:01 PM   #2
rocknbronco's Avatar
Re: check engine trick
OBD I or OBD II?
rocknbronco is offline   Reply With Quote
Old 01-09-2007, 04:13 PM   #3
Justin's Avatar
Send a message via AIM to Justin Send a message via Yahoo to Justin
take the negative cable off for about 30 secs and put it back on..should reset it...someone correct me if im wrong
http://www.mustangevolution.com/forum/signatureuploads/sigpic5474_2.gif
(Project "TORQUE"):burnout:
Mods - Off Road H w/ Flowmaster 40s and 3" x 22" Tips, Shiftkit, Shorties, and 4.10s
Soon to come - UDPs, Off Road X-Pipe, A/T Cooler, and 03' Cobra Rims
Club - Tha Crew Leader of Muscle Car Division
Justin is offline   Reply With Quote
Old 01-09-2007, 04:23 PM   #4
Try five minutes
Old 01-09-2007, 06:41 PM   #5
Scut95's Avatar
Give it a few minutes and it will go off. When you start driving again the car will go through it's checks and turn the light back on for the same problem as before if it wasn't fixed. Usually its a 3 cycle test meaning it has to fail the computers check 3 times before it turns the light back on.
Old 01-09-2007, 08:10 PM   #6
Originally Posted by rocknbronco View Post
OBD I or OBD II?
what the diference between OBD I and OBD II??
Old 01-09-2007, 08:35 PM   #7
remove the neg terminal from the battery tap the brake a few times and let it sit for like a few minutes. it will be off but if there is an issue it will come back on.
Old 01-10-2007, 01:32 PM   #8
Its how your cars puter is set up OBDII I feel is much better than OBDI cause you can get more accurate readings and most of the scan ports are easier to get to.In 96 all manufactures had to switch from I to II it for emissions controls pretty much.
check engine
Check ENGINE light..... SilverStang96 1996-2004 Mustang GT 26 08-11-2008 07:53 PM
Check engine came up NorwegianMustang Pre-2005 V6 Mustang 1 09-18-2005 01:54 PM
check engine light came on... red pony V6 Pre-2005 V6 Mustang 14 07-01-2005 08:24 PM
Check engine light Fishers Stang Pre-2005 V6 Mustang 3 03-14-2004 07:02 PM
11:29 PM
