bad battery - Mustang Evolution
Old 01-11-2007, 10:10 PM   #1
bad battery
a bad battery can turn on the "service engine soon " light???
carlosc is offline   Reply With Quote
Old 01-11-2007, 10:12 PM   #2
MonteCitan's Avatar
Re: bad battery
It could potentially set some 'improper battery voltage' codes but chances are it'll light up ABS/volts light before it affects anything engine wise.. (if its dying but not dead yet.._
2012 IS F Blue IS F Sport
2006 Mustang V6 wannabe
Old 01-11-2007, 10:24 PM   #3
Re: bad battery
ok this is my story . when i start the car the service engine soon sometimes is on and sometimes is off , but tonight i used my car and the service engine soon light do no appear , but later sed my car again and the rev down a litle mora than usual and the battery light and service engine soon appear, in 3 seconds the battery light turn off but the service engine stay on
PD, sorry , my english is not that good
Old 01-11-2007, 10:25 PM   #4
Re: bad battery
^^^ i needed to recharge the battery the last week, after that is the problem
Old 01-11-2007, 10:29 PM   #5
MonteCitan's Avatar
Re: bad battery
how low is the engine revving down to? if its almost down to a stall, could be an IAC or mass air issue, not enough volts with key on (IE low RPMs ) = volts light... and bad circuit on anything that would affect idle... would trip the check engine light, or could even be random misfire codes...
Old 01-11-2007, 10:36 PM   #6
Re: bad battery
is not possible that my problem is because the battery, is not possible that a new battery can solve the problem
pd the rev down a litle more than normal, not too much
Old 01-11-2007, 10:37 PM   #7
MonteCitan's Avatar
Re: bad battery
possible that its your battery, yes... could be a failing alternator, too... alternator drops output suddenly, your RPMs will drop as the car starts to run off battery only then compensates...
Old 01-11-2007, 10:51 PM   #8
Re: bad battery
monte citan thanks for the info, i ll buy a new battery , i forgot to tell you that when i recharged the battery the baterry only charged to half , not completly like i good battery should do, that why i think is the battery.
pd thanks, and sorry for my english, i speak spanish
Old 01-12-2007, 10:36 PM   #9
Re: bad battery
Where are you located? If you are anywhere near an Auto Zone or similar auto parts store they can check both your battery and alternator to see if either one of those are your problem. Around here they don't charge for either one.
Might be cheaper than having to buy a battery if that isn't the problem in the end.
Old 01-12-2007, 11:41 PM   #10
Titus Wadicus
svtlx's Avatar
Re: bad battery
yo quero muey bonita mustang para mi!!!
Old 01-13-2007, 01:11 AM   #11
Re: bad battery
jajaja like my english
Old 01-13-2007, 12:22 PM   #12
Titus Wadicus
svtlx's Avatar
Re: bad battery
HAHAHAHA.....IF YOU THINK THAT IS ****TY, I WRITE BETTER IN SPANISH THAN I SPEAK IT......LOL
Old 01-13-2007, 12:54 PM   #13
Re: bad battery
you understand what im trying to say, and i undestand that you want a beatiful mustang jejeje
Old 01-13-2007, 01:05 PM   #14
Titus Wadicus
svtlx's Avatar
Re: bad battery
simone...lol
When things go bad... they really go bad for some people Brent The Bar 8 12-13-2006 09:31 PM
Battery help lowflyn Pre-2005 V6 Mustang 8 11-26-2006 01:29 AM
Bad Fox, Bad Thomas91169 The Bar 17 11-23-2005 06:24 AM
Hillarys such a bad bad girl.... Brent The Bar 24 03-31-2005 04:41 PM
06:39 AM
