freeze plug leaking - Mustang Evolution
Old 08-03-2010, 07:04 PM   #1
freeze plug leaking
while changing the oil this week end i noticed coolent leaking under the motor and found it was the freeze plug,how hard is it to replace a freeze plug i have the 3.8 and the plug thats leaking is the front drivers side.it's not much of a leak but the plug looks corroded on one side and wet , should i stop driving the car until i fix it ? i thank everyone who takes the time to advice me on how to fix my ride.
coolmustanguy is offline   Reply With Quote
Old 08-03-2010, 07:37 PM   #2
Re: freeze plug leaking
As long as it doesnt start pouring out you should be fine. Check the radiator to make sure theres enough antifreeze in it and just buy a new plug. Easy fix.
pringle9666 is offline   Reply With Quote
Old 08-03-2010, 07:59 PM   #3
hottcobra's Avatar
not hard to change. first use a screwdriver and a hammer to punch the screwdriver through the old plug and then pry it out. Use a piece of sandpaper to clean the sealing surface of the block then smear RTV silcone around the edge of the new plug and use a socket or something close to the same size as the plug to tape it into place with a hammer.
Old 08-04-2010, 07:46 AM   #4
make sure you have enough access to not only remove it but put a new one in lol
Old 08-04-2010, 02:02 PM   #5
thanks very much
Old 08-14-2010, 09:06 AM   #6
I dont know about it being easy i havent done the one on my stang but my firebird was a pain you can run it like that but check you coolant i ended up having to replace one that compltley blew out you can get a rubber one at advance for like ten bucks a nice size pry bar and a hammer will do the trick
MyTang99 is offline   Reply With Quote
freeze plug shustwit Pre-2005 V6 Mustang 2 09-24-2008 06:14 AM
Leaking rear Calumus 1996-2004 Mustang GT 4 09-19-2008 04:41 AM
Leaking wiper spindles? theopenroad Classic Mustangs 2 06-03-2008 02:16 PM
Leaking Exhaust Manifold? 00vertstang Pre-2005 V6 Mustang 8 06-04-2005 07:16 PM
Leaking Transmission Fluid?.. Ibanezplayer272 Pre-2005 V6 Mustang 20 09-07-2004 02:40 PM
01:54 PM
