#2 misfire keeps coming back! Gggrrrr! - Mustang Evolution
Old 08-04-2010, 10:16 PM   #1
Unhappy #2 misfire keeps coming back! Gggrrrr!
Hi All! I have a 96 A/T V-6 that I have owned for only about 6months. Shortly after buying it I noticed it was misfiring at warm idle and the check engine light came on. I had it checked at Autozone and it showed #2 cylinder misfire. I replaced the coil, plugs and wires and added some prem gas and a bottle of lucas to clean out the system. Code cleared, misfire stopped!
So over the last few months, anytime I got down to about 1/4 of a tank of gas and romped on it to pass someone, it would start misfiring at idle again. I added more cleaner and prem. gas, checked plugs and wires and then it would clear up on its own.
Since it did this several times, I figured it had to be the fuel filter and maybe some crud was getting kicked up, so I have now replaced that as well. As of last week the misfiring is back and now the previous "fixes" aren't working to clear it up. I bought a new injector but I really am hoping it doesn't come to that (taking the fuel rail off is not something I want to do). I haven't checked the compression yet but it seems to be ok.
The misfire is only at warm idle; it smooths out when I am driving. The plugs are gapped correctly, there doesn't seem to be any arcing... Any suggestions would be sooooo appreciated!!
Sunrunner is offline   Reply With Quote
Old 08-05-2010, 02:07 PM   #2
Re: #2 misfire keeps coming back! Gggrrrr!
you checked the plugs? also for gap etc (if you take em out replace them) also inspect plug wires for burn places etc
Old 08-05-2010, 09:54 PM   #3
Thanks Spector, I've replaced the plugs, wires and coil twice now in 6mths. The plugs were gapped to 0.055. I am gonna try cleaning or possibly replace the MAF sensor tomorrow. Hopefully that will fix it for good this time cause I really do not want to have to do the injector!
Old 08-15-2010, 10:43 AM   #4
James02Mustang's Avatar
You are spending a lot of money that you don't need to. The MAF will not cause 1 cylinder to misfire. Same with the coil, it is a waste spark coil so 2 cylinders fire together, if the coil was bad and causing cylinder 2 to misfire, cylinder 6 would misfire too. It is probably the injector, get a pressurized fuel injection cleaner or pull the injectors and have a shop clean them. The in the tank cleaners generally do not work well. Also the reason the misfire stopped after the cleaner with premium gas is probably only because of the higher octane.
James02Mustang - V6KR - Stroked/Forged/Blown 4.2L V6
Official Project Site - www.mustangjames.blogspot.com
James02Mustang is offline   Reply With Quote
Old 08-15-2010, 01:05 PM   #5
Sounds like an injector issue since it's only on that cylinder. Especially since you have done wires and plugs.
It's really not that big of a deal to pull the fuel rails and just have all 6 cleaned.
Old 08-15-2010, 02:21 PM   #6
meteorachick's Avatar
did you swap out the coil pack? that fixed my misfire before
Modified 2004 V6
Old 08-16-2010, 02:46 AM   #7
SaleenFiend's Avatar
Not always true James. I've replace plenty of coils with only one misfire per two cylinders.
I agree though have your injectors and fuel rail blown out and cleaned. I would also make sure there is no damage to any of the wiring or harness for the fuel system.
Old 08-16-2010, 10:32 AM   #8
Thanks for all the info, guys! I really appreciate your input and I will do as recommended and check the injector. I have done most of my own work on my cars but I haven't yet pulled the fuel rail off and cleaned or replaced injectors. I guess I am letting my car intimidate me LOL Ok, so I am going to have to wait till I am off this coming weekend but I will let y'all know what I find!
Thanks again,
Kimberly~
Some random pics from coming back to the States SrATEX Pictures and Videos 5 07-25-2006 09:05 PM
Futurama coming back in 2008 SilentNoise The Bar 9 06-23-2006 01:04 PM
Brett Favre is coming back Brent The Bar 9 04-26-2006 03:46 PM
vibration coming from the back Sublime782 Pre-2005 V6 Mustang 4 07-11-2005 07:08 PM
Is the chatroom ever coming back? Ken The Bar 3 01-31-2004 12:35 AM
06:20 AM
