reverse - Mustang Evolution
Old 01-17-2007, 09:16 PM   #1
reverse
i have a question, when a drive all the gears fells ok, but when i press the clucht a tried to use "reverse" , the 1st time that i try the gear is stock or something, then put in neutral and try agai and everything ok, is just the first time
is that normal o what??
...other thing when accelerate i hear a sound, like a vaccum or turbo in the right side of the dash..the car have a cold air intake,
this sound is the CAI working???
carlosc is offline   Reply With Quote
Old 01-17-2007, 09:25 PM   #2
Re: reverse
^^^^gear ,shift i dunno
Old 01-17-2007, 09:29 PM   #3
bbunt302's Avatar
Re: reverse
What year and model car is yours again? V6 I assume?
If so, it has a T5, which are notorious for having problems going into reverse. So it's pretty normal to have problems getting it to go into reverse at first.
And yes, that sound you are hearing is most likely from the CAI.
Scary stuff.
Old 01-17-2007, 09:44 PM   #4
Re: reverse
is a v6 3.8 2001, has the stock trans
Old 01-17-2007, 09:47 PM   #5
Re: reverse
...and 4 to 5 makes a sound like grinding , but not exactly , the others 1 - 4 is perfect
Old 01-17-2007, 09:48 PM   #6
Re: reverse
^^^anyway i dont use 5 very much
Old 01-18-2007, 06:53 AM   #7
Re: reverse
I never had any issues in my 01 shifting into reverse but I always took care of my trans by shifting only when fully stoped into reverse and changing the fluid etc etc, some are just bad. Be glad its not happening on your 5th gear shift (which is also a VERY eask gear so never speed shift into it or abuse it)
Old 01-18-2007, 07:51 AM   #8
MonteCitan's Avatar
Re: reverse
It might help if you try shifting into 5th first (just moving the gearshift into it, not releasing the clutch of course) then pulling it back to reverse...
2012 IS F Blue IS F Sport
2006 Mustang V6 wannabe
Old 01-18-2007, 08:37 AM   #9
Re: reverse
this issues in 5 ( sound like somithing is stock in 4 -5) and that sometimes i cant shiftgear into reverse the first time i try can damage the trans or is something that cant cause major problems?
Old 01-18-2007, 08:57 AM   #10
MonteCitan's Avatar
Re: reverse
If its grinding 4-5 it could be either a clutch engagement issue (not likely if the others are fine.. ) or it could be a 5th/reverse synchro or possibly bent fork? something to think about... might need a rebuild
Old 01-18-2007, 09:01 AM   #11
Re: reverse
1- 4 is perfect, no grinding , no problems in 1 - 4
Old 01-18-2007, 08:59 PM   #12
Re: reverse
ok an update..
2 hours ago i drive my car (v6 2001) and remember the grinding sound in 4 - 5 , ???
i park the car and press the clutch and start shifting 1 - 5 and everything it was well but if loose the clutch and press it again and shift to 5 its makes the noise and the spedometer raises while it makes the noise, just for less than a second
Old 01-18-2007, 09:00 PM   #13
Re: reverse
hat can causing that???
reverse gear grind chris098 1996-2004 Mustang GT 8 01-21-2008 09:49 PM
reverse damage sonicpony Pre-2005 V6 Mustang 14 04-01-2007 09:12 AM
reverse glow gauges V6STANG007 Mustang Audio & Video 8 05-05-2006 09:21 AM
Noise when I reverse!!!!!! latinimagexx Pre-2005 V6 Mustang 3 04-16-2004 06:44 PM
Reverse lights Laser02 Pre-2005 V6 Mustang 10 11-03-2003 08:07 AM
10:31 AM
