Ride Height Change - Mustang Evolution
Old 08-09-2010, 12:57 PM   #1
obxdude018's Avatar
Ride Height Change
Ok I have a set of frpp lowering springs (1.5") on my car, I just installed a UMI adj. upper control arm and j & m extreme lower control arms, when I lowered the car back down the ride height in the rear shifted up, it looks like it is setting on stock springs again, would this be just the adjustment on the upper control arm to bring the rear back down again.
obxdude018 is offline   Reply With Quote
Old 08-09-2010, 01:30 PM   #2
Re: Ride Height Change
if just installing those parts raised the car up then something could be in a bind or the lower control arms could be longer or something? but that doesnt make since.
You install poly or stiffer/thicker isolators with the lowers? They may also have a higher perch (same difference as thicker isolators). Does their FAQ or anyone you talked to on their end mention that this happens?
Old 08-09-2010, 01:39 PM   #3
obxdude018's Avatar
It is poly with the lowers. It just seems strange for it to back that high, also considering it puts more weight on the front wheels now.
Old 08-09-2010, 02:17 PM   #4
the weight it puts i dont think would alter it that much, its probably the poly bushings, take them out and just see how it changes.
Remember you have poly in top and bottom and that can add up to be QUITE a bit of increase.
Old 08-09-2010, 02:22 PM   #5
obxdude018's Avatar
After back and forth deliberation it appears to be just the drivers side that is up, not sure if the panhard bar has anything to do with this or not, the passenger side sets at 27 5/8" and the driver side is at 28 1/8", the measurement was from ground to the bottom of the fender.
Old 08-10-2010, 07:31 AM   #6
hmmm make sure you are on level ground, you can probably rather easily unbolt the panhard to check for binding. Jack the car up to see if the suspension travels smoothly as well. Take a pic on the ground and jacked up and compare the tire position it shouldnt shift that much in pushed in/out
stock height?!? carlosc Pre-2005 V6 Mustang 2 01-21-2009 07:27 AM
Scooter + Car = Good Height and Rotation PureVenom Pictures and Videos 12 10-27-2008 10:31 AM
My New RIDE ridenmystang Pictures and Videos 44 08-15-2007 03:15 PM
Basketball Star Wannabe Sues Over Height sctalbott The Bar 11 10-10-2004 09:21 AM
My Ride: MarkuzLS1 Pictures and Videos 49 08-04-2004 08:47 AM
09:47 PM
