piston rod combos - Mustang Evolution
Old 01-26-2007, 11:52 PM   #1
piston rod combos
well its been a while my 2000 mustang i got my engine apart and piston number 6 was breaking up between the compression rings.. and when i took the rings off the metal came out on parts between the compression rings. number 5 is starting to crack between the compression rings. The rest are ok so im going to be rebuilding the engine with new valves lifters valve springs pistons rings rods bearings. my question is whats the best place to get forged piston rod combo at a decent price. and if i get all this somewhere would they offer a discount
jedwards242000 is offline   Reply With Quote
Old 01-29-2007, 01:13 PM   #2
rydog's Avatar
Send a message via MSN to rydog
Re: piston rod combos
Try here Super Six Motorsports
97 V6-GT40 turbo-42#rs-BA2800 MAF-4.10's & tlok-254rwhp-369rwtq
Turbo'd by-TMA Turbo(http://www.tmaturbo.com/)
Tuned by-Dyno Tuned Performance(http://www.dtpracing.com/)
rydog is offline   Reply With Quote
Old 01-29-2007, 04:04 PM   #3
Region: Iowa
Send a message via AIM to Horse Send a message via Yahoo to Horse
I'd go with RPM (Redline Performance Mustang) I've gotten stuff from both SSM and RPM, and I prefer RPM
Redlined Performance Mustangs
4.2L , CAI, BBK 65MM throttle body, 30lb injectors, SSM ported intakes, FLEX 1/2" spacer, RPM big valve heads, Comp roller rockers and cam, ASP-underdrive pulley, GT rear swaybar, & Quad Shocks, Full MM Coilover conversion, 17" Grey Torque Thrust wheels, FMS Aluminum driveshaft 8.8 rear w/ 3.73 gears, Tri-Ax Shorthrow shifter & SPEC stage II clutch w/ aluminum flywheel
Horse is offline   Reply With Quote
Old 01-30-2007, 01:28 AM   #4
ty for the info guys ill check them both out and see what is the best option for what im trying to do
Old 01-30-2007, 02:19 AM   #5
I bought all my stuff from RPM however he has recently cut back on his business.
Old 01-30-2007, 05:07 AM   #6
slvr2000stang's Avatar
Another good place to buy from is Delk Performance.
Talk to Matt.
Custom Delk motor now DOA
2003 SVT Lightning #1059 of 4270
2000 Vert 4R70W
Only buy from vendors that test and stand behind their products
slvr2000stang is offline   Reply With Quote
Valve to piston clearence? 93_5.0_JW 1979-1995 Mustang GT 1 04-03-2009 03:58 PM
I detonated a piston on my car 80( supercharged04 New Member Introductions & Greetings 9 04-30-2007 09:13 PM
piston rings ? jedwards242000 Pre-2005 V6 Mustang 12 11-04-2006 07:37 PM
Pacer And Piston Game! Seph The Bar 35 11-23-2004 01:39 PM
11:25 AM
