V6 Mustang Valve Clatter - Mustang Evolution
Old 01-28-2007, 04:46 AM   #1
I have 1996 Mustang with the 3.8 liter. I am having a problem with valve noise. From the valve train area there is a faint rattle all the time and valve ticking after warm up. I also had a problem with low oil pressure. I replaced the pump and the pressure looks O.K. now. I am hoping it is a problem with the lifters.
I suspect it is something more severe but does anyone know if a problem with the lifters could be one cuase of these symptoms?
csquared4711 is offline   Reply With Quote
Old 01-28-2007, 11:39 AM   #2
rocknbronco's Avatar
Re: V6 Mustang Valve Clatter
it could be fuel related what octane rating are you running?it's very remote from the sounds of it but it still could be it.
rocknbronco is offline   Reply With Quote
Old 01-28-2007, 07:27 PM   #3
what are you using to check the oil pressure?
Old 01-31-2007, 09:45 AM   #4
Danger Dude's Avatar
Lifters can cause ticking. so can a small exhaust leak. You could also have a fault PCV valve. Low octane gasoline can also contribute to this. If you live in a place with crappy gas it can be a problem.
v6 mustang
Bypass valve & Blowoff valve sporter 2005-2010 Mustang GT 7 05-27-2007 02:57 PM
11:35 PM
