Help quick! Abs module! - Mustang Evolution
Old 08-21-2010, 10:50 AM   #1
CHILE10_STANG's Avatar
Unhappy Help quick! Abs module!
SO MY ABS LIGHT USED TO TURN ON AND OFF AND LIKE A MONTH OR TWO AGO IT DECIDED TO STAY ON.
I HAVE A FRIEND AT THE SERVICE PLACE AT THE FORD DEALER AND HE SAID IT WAS THE MODULE WHICH NEW RUNS FOR ABOUT 800. I ORDERED THE PART LAST WEEK FROM PRESTIGEMUSTANG AND GOT IT INSTALLED YESTERDAY BUT THE THING WAS BAD!
I CALLED THE PLACE AND THE GUY THAT WORKS THERE AND SEEMS TO RUN THE PLACE (TODD) SAID I COULD SEND IT BACK AND HE WOULD SEND ME A NEW ONE. HE SAID HE JUST GOT A GT MODULE WITH TRACTION CONTROL AND IT WOULD WORK ON MINE JUST FINE (MINE HAS TRACTION CONTROL TOO BUT IS A V6) ANY CLUE IF IT WILL WORK?
UGGHH AND BEFORE I BOUGHT IT I CLEARLY ASKED IF IT WAS WORKING
THANKS!
IMPOSSIBLE IS NOTHING
2000 MUSTANG V6
2001 MUSTANG GT
2014 MUSTANG GT
CHILE10_STANG is offline   Reply With Quote
Old 08-21-2010, 11:33 AM   #2
Re: Help quick! Abs module!
no clue either my abs light is on too i have a 95 gt
wizud222 is offline   Reply With Quote
Old 08-23-2010, 01:42 PM   #3
NO ONE HAS ANY IDEA?
2000 MUSTANG V6
2001 MUSTANG GT
2014 MUSTANG GT
Old 09-02-2010, 10:14 AM   #4
racefan966's Avatar
Region: Idaho
If you would have your friend to scan it and get back to me with the code that you find. Once you have the code I will look it up on Mitchelle and tell what tests you will need to run to figure out what you need to replace. If you do find out it is a module then I would buy one from a wrecking or salvage yard it shouldn't cost more then about 185 dollars. I do not find any service bullitens that tell me these have a problem with the modules so no reason a used one won't work and most yards do give a short warranty. As for is the GT is different from the 6 cyl one I do not think it is but give me the year and and part number off the old one and I will check that too.
racefan966 is offline   Reply With Quote
Help! Fuel Pump Module BIGIE Pre-2005 V6 Mustang 0 06-05-2009 05:09 PM
jet performance module upton7 1996-2004 Mustang GT 3 05-24-2009 01:51 PM
JET module mitch Pre-2005 V6 Mustang 5 06-18-2007 02:12 PM
Parting out? I need GEM module I_luv_HP&trq Pre-2005 V6 Mustang 0 01-07-2006 05:32 PM
Venom 400 Control Module greenpony02 Pre-2005 V6 Mustang 1 03-15-2004 03:24 PM
07:51 PM
