first mod!! - Mustang Evolution
Old 08-24-2010, 06:08 PM   #1
soccerfreak2143's Avatar
Thumbs up first mod!!
so i finally got to buy a tuner. i went with the sct sf3 from AM...the free tunes for life program will be nice for future mods.
iv only gotten to try the street tune so far, but i already love it. the shifting difference is great. iv heard that the race tune is pretty hard on the transmission though...is it bad to run it on that tune very much?
soccerfreak2143 is offline   Reply With Quote
Old 08-25-2010, 06:18 AM   #2
Re: first mod!!
I would say it wouldn't really hurt anything. Especially on a stock car. It really just depends on your driving habits.
tigerfan2771 is offline   Reply With Quote
Old 08-25-2010, 07:56 AM   #3
Re: first mod!!
actually faster shifts is better, the slower the shift the more heat/friction that builds up. This is of course not always the case but in normal driving faster shifts are better for the life of the trans (just like changing its fluid every 20k AT LEAST is something you should do)
Old 08-25-2010, 09:59 AM   #4
Re: first mod!!
Run that thing..... it is a ford
zztop1234 is offline   Reply With Quote
Old 08-25-2010, 10:19 AM   #5
Re: first mod!!
So your saying its meant to break? Lol.
Old 08-25-2010, 01:38 PM   #6
Re: first mod!!
ok, i was jw cuz i floored it with the street tune and the shift was pretty hard, i didnt know if it would be like that with the performance and race tune.
also, is it bad to run a higher octane gas before you switch tunes?...like using 89 if its tuned for 87?
Old 08-25-2010, 01:52 PM   #7
Re: first mod!!
you can run 89 if its tuned for 87 no issues, but its not going to help anything (other than if you picked up bad gas and 89 is a "buffer" if you will
Old 08-25-2010, 01:55 PM   #8
Region: Iowa
Re: first mod!!
You should be fine running the higher octane (just don't run lower octane). When the tunes were done by Bamachips, I heard with the race tune they further adjust the drive-by-wire response of the throttle, so it is a bit touchy with street driving. They should also be able to provide a tune that either optimizes torque or HP (depending on what you want).
NQSperformance
Vendor for:
American Muscle - Maximum Motorsports - Stack Racing - Koni - Tokico - H&R - Eibach - Hawk - Powerslot
John@NQS is offline   Reply With Quote
Old 08-31-2010, 10:51 PM   #9
tvsr's Avatar
Region: Nevada
Re: first mod!!
listen to spectorV
tvsr is offline   Reply With Quote
Old 08-31-2010, 10:59 PM   #10
02Nate281's Avatar
Send a message via AIM to 02Nate281 Send a message via MSN to 02Nate281 Send a message via Yahoo to 02Nate281 Send a message via Skype™ to 02Nate281
Re: first mod!!
Not to get off subject, but I checked out the NQS website and I was NOT impressed.
And SpectorV is right.
"There is no love without sacrifice"
02Nate281 is offline   Reply With Quote
Old 08-31-2010, 11:52 PM   #11
1ijack's Avatar
Send a message via Yahoo to 1ijack
Re: first mod!!
I think the biggest thing you will find out about the tunes is the response you get from the computer. I run 89 in mine and i dont have a problem at all.
The Mustang Mafia
"Join the family, if you dare"
www.themustangmafia.com
1ijack is offline   Reply With Quote
Old 09-01-2010, 02:47 AM   #12
Talking Re: first mod!!
Sorry people but i'm putting in a s/c motor out of a thunderbird and was wondering if i had to change my computer or get it tuned. I have a 94 convert stang and i believe is still obd1 and since the s/c motor is obd1 i thought maybe it would work, if not then can anybody help me on where a good place is to have my computer programed. Also sorry i know most of you are probley sick of answering ? about s/c motors.
Straublittleman is offline   Reply With Quote
Old 09-01-2010, 03:22 PM   #13
02Nate281's Avatar
Re: first mod!!
You could buy a tuner online and the place you get it from will usually send you tunes and walk you through the process the first time. Or you could take it to a dyno shop if you have the money.
Old 09-02-2010, 02:16 AM   #14
Re: first mod!!
But thats another thing i can't find a tuner for the 94 v6 they're all for 96-up at least i havent seen one yet, but another thing is that i've read on other forums/posts and they've never said if they HAD to tune the computer. I havent put the motor in yet but was wanting to make sure i had everything first, it will be a winter project since i don't drive it in the winter "salt/and to slippery" i have a ford ranger 4x4 for the winter.
Old 09-02-2010, 03:16 AM   #15
02Nate281's Avatar
Re: first mod!!
You will most likely have to get the wiring harnesses and ECU from the T-bird engine and install it or have it installed by someone in the new car.
Old 09-02-2010, 08:53 AM   #16
racefan966's Avatar
Region: Idaho
Re: first mod!!
You will either need to tune it (have you computer reprogrammed) or better yet use the the computer from the T-bird. Your car is OBD1 but it is not tuned or set up for the charger. As for the 87 and 89 octane, if you are tuned for 87 then buying the higher octane will not hurt but it won't gain you anything either.
racefan966 is offline   Reply With Quote
Old 09-02-2010, 09:09 AM   #17
Re: first mod!!
dont do the supercoupe supercharger on your v6, its not worth it and you have to pretty much replace the entire engine to make it work.
Old 09-02-2010, 10:05 AM   #18
racefan966's Avatar
Region: Idaho
Re: first mod!!
Spector is correct after thinking about it the compression ratio is not the same and so on. If you are going to spend that kind of money go to a procharger or do a 4.2 swap.
Old 09-02-2010, 12:35 PM   #19
Re: first mod!!
I have the complete motor and everything else but the computer but the t-bird computer has a different plug, and the motor was give to me with about 36,000 miles on it. Does anybody know where i can get a tune for it?
Old 09-02-2010, 12:38 PM   #20
02Nate281's Avatar
Re: first mod!!
Try calling some local shops around you. Chances are if they can't do it they know a shop that can.
Old 09-02-2010, 02:09 PM   #21
Lone Star's Avatar
Re: first mod!!
No that's Chevy! LOL
Northern Virginia Mustang Club
Silver Mustang Registry #1045
2010 Brilliant Silver 4.0 V6 Traded and will be missed
2011 Performance White Premium GT 5.0 6MT, 19" Machined Wheels, 3.73 gears, GT500 Axle-Backs, Eibach Pro Springs, Dynojet #'s 387rwhp/380 tq.
Lone Star is offline   Reply With Quote
First Mod Done Bgover Pre-2005 V6 Mustang 6 08-21-2009 02:47 PM
next mod Senorjizzy Pre-2005 V6 Mustang 7 07-29-2009 09:52 PM
new mod Kyle Pictures and Videos 22 10-08-2007 11:43 PM
What should my next Mod be? tippie2000 Pre-2005 V6 Mustang 24 04-07-2004 03:49 PM
next mod: Rellik The Bar 11 10-18-2003 08:03 AM
02:32 AM
