19"wheels rubbing - Mustang Evolution
Old 08-30-2010, 12:57 AM   #1
19"wheels rubbing
I just got a set of 19" GT wheels and tires that were new take-offs from a local Ford dealer. $799 for all, I couldn't resist. The tires are Pirelli 245/45/19's. I've installed them on my son's 2009 V6 coupe replacing the 16" original equipment, and they look great but they frequently rub on the frame when turning tight. I ordered a set of Roush steering stops at $9.95 a pair from American Muscle. Will this solve the problem? Would a set of wheel spacers that mover the rims outboard be in order or helpful and what would be a minimal thickness recommendation? We eventually plan on lowering slightly. Thanks for any help
reegus58 is offline   Reply With Quote
Old 08-30-2010, 07:17 AM   #2
Re: 19"wheels rubbing
I assume since 19 inch rims they are made for an 05+ vehicle (are they oem ford rims?)
If they are OEM ford they should fit no issues~ if they do rub when the wheel is turned fully then what you ordered may very well work fine as my car has stops from the factory to keep the wheel from turning as much since it had wider tires than more.
Can you give us some more information on the rims/tires you picked up, pictures perhaps?
I know if you put 05+ mustang rims on pre 05 cars they sit in to much and rub when turning.
Old 08-30-2010, 09:03 AM   #3
Thanks for your reply. I believe these wheels were taken from a 2010 GT. I can see on the frame where they have left clean marks. I checked specs from Tire Rack which say this set up is 7/10's" taller than the original 16" wheel & tire combination. We've gained about an 1 1/2's in gap between tht top of the tire to the fender opening. The 245/45's are very wide so there no issues on the fender lips. I just registered last night and am unfamiliar with this whole format. Hopefully I've attached a pic of the wheels. If not they are the ones on the car in my profile photo. Thanks again
Name:	New 19in wheels.jpg
Old 08-30-2010, 09:15 AM   #4
I meant to say the 245/45's are "not" very wide
Old 08-30-2010, 03:08 PM   #5
its odd that they rub on anything, those rack limiters may do the trick. Is the speedo off any, if the height of the tire is taller than the stock it will be off~ also do you have the tire sensors on the car (the rims have them but if you car doesnt no big deal you dont have to sync them with the car so they read the tire air pressure)
Old 08-30-2010, 03:44 PM   #6
You can see on both sides,ahead of the wheel, an arc shaped mark. 90% of it is on the plastic wheelhouse,but the bottom of the mark finishes on the frame just below where the button type fastener attaches the plastic. I'm eager to see how much the turning radius will be affected. The spacers are only 5mm. Thanks for your input. I'm sure I'll post a bunch more questions. I haven't messed much with newer Mustangs, this '09 is my son's car, mine is a '65 GT fastback
Name:	Mustang in yard.jpg
Old 08-30-2010, 04:06 PM   #7
02Nate281's Avatar
Send a message via AIM to 02Nate281 Send a message via MSN to 02Nate281 Send a message via Yahoo to 02Nate281 Send a message via Skype™ to 02Nate281
Gorgeous
"There is no love without sacrifice"
02Nate281 is offline   Reply With Quote
Old 08-31-2010, 07:33 AM   #8
keep us updated on if it fixes it, if it does then we know they put spacers on the new ones for sure to limit turning radius.
Old 08-31-2010, 10:47 PM   #9
tvsr's Avatar
Region: Nevada
hmmm... I have 20 in. rims and they never scrap or nothing like that, maybe the with is too big for your car. 2010s are the new mustang models, maybe they're not the same as the 09
tvsr is offline   Reply With Quote
Old 08-31-2010, 11:00 PM   #10
They appear identical to those offered in '09, but maybe they changed the offset? I'm going to try look up the part #'s to see if they were different between '09 & '10. I suspect it's more likely that my sons car is a V6 and has a softer suspension than the Gt's or maybe the cars that got 19's also got thicker steering stops? Hopefully the Roush stops I've ordered will eliminate the rubbing (and cheaply). They look to be an easy 20 minute install.
Old 09-01-2010, 07:56 AM   #11
you can measure front spacing/backspacing very easily there is an article about what is what. You can compare it to his current wheels to see how they differ in fitment.
Mustang Wheels and Tires FAQ
whos used rubbing compound? Zim Mustang Audio & Video 2 08-09-2006 05:49 PM
Rubbing Scut95 1979-1995 Mustang GT 8 01-19-2006 01:17 AM
Rubbing Alchohol StreetRacer4371 The Bar 7 11-08-2004 12:53 PM
Fixed my "rubbing problem" greenflash00 The Bar 2 02-18-2004 10:51 AM
Getting some rubbing up front...any suggestions? greenflash00 Mustang Wheels & Tires 18 02-08-2004 12:42 PM
12:34 PM
