redline differential oil question - Mustang Evolution
Old 03-13-2007, 09:16 PM   #1
Region: Iowa
Send a message via AIM to Horse Send a message via Yahoo to Horse
Redline says that their lightweight shockproof gear oil has similar properties to 75w90 gear oil but only works where the differential is at "lower temperatures."
Has anyone used the shock proof in their diff, and does anyone know if an autocrossed 8.8" rear end counts as "low temperature?"
Thanks
4.2L , CAI, BBK 65MM throttle body, 30lb injectors, SSM ported intakes, FLEX 1/2" spacer, RPM big valve heads, Comp roller rockers and cam, ASP-underdrive pulley, GT rear swaybar, & Quad Shocks, Full MM Coilover conversion, 17" Grey Torque Thrust wheels, FMS Aluminum driveshaft 8.8 rear w/ 3.73 gears, Tri-Ax Shorthrow shifter & SPEC stage II clutch w/ aluminum flywheel
Horse is offline   Reply With Quote
Engine Oil Question drkchocolate07 Pre-2005 V6 Mustang 6 07-17-2008 10:21 AM
Oil Dipstick Question Kiljosh Pre-2005 V6 Mustang 9 03-16-2006 03:55 PM
Oil pan question... lowflyn Pre-2005 V6 Mustang 9 03-15-2006 05:14 PM
Redline advice for 05' jones4stangs Pre-2005 V6 Mustang 5 10-25-2005 11:23 PM
08:35 AM
