94 3.8 - Mustang Evolution
Old 09-02-2010, 07:45 PM   #1
94 3.8
white smoke comes out my muffler when i first start it it shakes when idleing my dad adjusted the timing it runs alright but sucking gas im going threw $20 a day i pulled out my dipstick n smelled gas a friend told me it was my timing chai i changed my oil n filter n still smell gas im afraid 2 drive it bcause some1 told me it could blow up please help me
shady is offline   Reply With Quote
Old 09-02-2010, 07:47 PM   #2
Re: 94 3.8
Old 09-07-2010, 08:53 PM   #3
Re: 94 3.8
Well for one that sensor your dad turned to adjust the timing doesn't adjust the spark timing it controls the injectors and controls transmition shifts is its auto. If it smokes only when you first start it, it needs valve seals. But it sounds like you're needing a good tune up or your coilpack is failing. But with the timing the computer controls that.
Straublittleman is offline   Reply With Quote
Old 09-08-2010, 12:33 PM   #4
Herbstang's Avatar
Re: 94 3.8
valve seal is leaking. oil drip pass valve seal into the cylinders. when starting engine up it is burning it up and remaining oil blow out of tail pipe.
Old 09-15-2010, 06:44 PM   #5
racefan966's Avatar
Region: Idaho
Re: 94 3.8
Could be either or but get that cam shaft sensor back where it was so it will quite using so much fuel. Then pull spark plugs and see what they look like and go from there.
racefan966 is offline   Reply With Quote
Old 09-15-2010, 09:21 PM   #6
Re: 94 3.8
i meant my dad adjusted the distrubutor i put new plugs n wires n 2 02 sensors still sucking gas u said my dad should turn the distrubutor back
Old 09-15-2010, 09:23 PM   #7
Re: 94 3.8
Old 09-15-2010, 09:28 PM   #8
Re: 94 3.8
94 3.8L v6 didn't have a distributor they had a cam sensor instead. But if its v8 5.0 then yeah they had a distributor.
Old 09-15-2010, 09:33 PM   #9
Re: 94 3.8
Or do you have a thunderbird?
02:33 PM
