Knocking 3.8 - Mustang Evolution
Old 03-23-2007, 03:43 PM   #1
Knocking 3.8
OK guys, my daughters 94 3.8 with 50 K miles started knocking when you rev it to 2000 rpm or above even in neutral. It has always run like a "pig" even slower than I would expect from only 145 hp pushing it. Can blip the throttle and it doesn't even rev untril about the time you have already closed the throttle.MAF was bad but even a new one didn't make a big impact.
You could rotate the motor by hand and hear a clunk. Balancer is OK not worn, no loose convertor bolts.
The knocking sounds high like under the intake plenum. Sounds like a rod, wrist pin but high. In the process of pulling motor, pulled pan and all the rods look good no heat color change or loose rods.
We'll pull it this weekend and look it all over.Any other areas to look at?
What things would be cost effective to pick it up a little in performance while out for a daily driver for a high school kid? before this she drove my 81 Trans Am that had a stock 400 motor, and definitely a step down in performance,but fewer miles ie things to go wrong, and an air bag than the TA.
Maybe add a 4.2 crank?
Skip Fix is offline   Reply With Quote
Old 03-29-2007, 02:00 PM   #2
Re: Knocking 3.8
Update for you all. It ended up being the wire from the head gasket had squeezed between the piston and quench area of the head and was getting hit as the motor reved.
Old 03-29-2007, 02:45 PM   #3
rydog's Avatar
Send a message via MSN to rydog
Re: Knocking 3.8
Well thats some random **** there
97 V6-GT40 turbo-42#rs-BA2800 MAF-4.10's & tlok-254rwhp-369rwtq
Turbo'd by-TMA Turbo(http://www.tmaturbo.com/)
Tuned by-Dyno Tuned Performance(http://www.dtpracing.com/)
rydog is offline   Reply With Quote
Old 03-29-2007, 02:47 PM   #4
Re: Knocking 3.8
Yea don't hear about that happening very often.
Old 03-29-2007, 05:25 PM   #5
silverstangboy's Avatar
Re: Knocking 3.8
interesting indeed.
the only thing performance wise that I would even really consider might be to have someone lightly port the heads and intake... leave the cam ALONE!
93 mustang notch
~450hp 331 stroker - Sold
Old 03-31-2007, 09:26 PM   #6
meteorachick's Avatar
Re: Knocking 3.8
i definately would not have thought that
Modified 2004 V6
Engine Knocking NotoriousSPG Pre-2005 V6 Mustang 10 07-08-2010 04:42 PM
Knocking noise Foxone General Mustang Discussion 6 10-28-2009 10:38 PM
Help me diagnose this knocking Kiljosh Pre-2005 V6 Mustang 7 05-25-2007 10:41 PM
Knocking sound? Ibanezplayer272 1979-1995 Mustang GT 4 12-04-2004 10:43 PM
Knocking engine Black Panther Pre-2005 V6 Mustang 25 11-02-2004 06:57 PM
12:05 PM
