Squeaky Struts and steering wheel - Mustang Evolution
Old 03-25-2007, 12:38 PM   #1
Kiljosh's Avatar
The passenger side of my car has started to squeak when I go over any small bump, also when I turn the wheel it starts to squeak. Kind of sounds like your dragging rubber over clean metal. I think the cause of this is from the accident I had 4 months ago where I hit a guardrail with my passenger side around 15-20 mph after treacherous oversteer. Does this sound like this will hold any water, if I have to replace the strut should it clear up the steering problem you think?
I have a feeling the squeaking while steering is coming from my system's power wire going through the grommet on the column. It sounds like it is rubbing on the metal and the insulation is making it squeak.
(never mind the wire doesn't go out that grommet, I was thinking my Honda...)
Old 03-25-2007, 12:47 PM   #2
crazeflier07's Avatar
Send a message via AIM to crazeflier07
Re: Squeaky Struts and steering wheel
I dont know but I have a bad passenger side ball joint and I think my squeeking is coming from there. Check on the bottom of your Kmember where the steering pieces are and see if anything is showing or looks worn. Just guessing since I cant see or hear it.
~Jon~
Sinister Six
1998 3.8L V6
Done So Far:
~CAI, True dual exhaust, UDPs, MGW Shifter, H&R springs, Stage 1 & 2 supension kit, performance rotors & pads, steel braided lines, 1 inch rear spacers, A.R. Rebel 17x9s with BFG rubber! :thumbs2:
crazeflier07 is offline   Reply With Quote
Old 03-25-2007, 04:30 PM   #3
megax29's Avatar
Send a message via AIM to megax29 Send a message via Yahoo to megax29
I have the same exact problem. It's so annoying it happens when I accelerate and the weight shift back, when I break and the weight goes to the front and when I make a turn. I also hit a guardrail while trying to steer around a dog. I thought I needed some wd40 but I wanted to ask for any suggestion of area I should look at.
V6 Midnight Black
CAI w/ K&N Filter, Tokico Complete Suspension kit, Single Flowmaster w/ turndown, GT rear sway bar.
megax29 is offline   Reply With Quote
Old 03-26-2007, 02:16 AM   #4
Kiljosh's Avatar
I am thinking Bullitt handling Kit if its the struts, I was under there changing my oil soon after posting. All the bushings that I can see look like they are in pretty decent shape. The squeak happens when I push down on the passenger side, on the down stroke doesnt squeak on the way back up. hmm
Old 03-26-2007, 05:05 AM   #5
MonteCitan's Avatar
We used to have a frequent problem with this on the 99+ mustangs, not sure if the older ones had the same issue -> The bushing and/or the metal sleeve for the bolt to the steering rack, usually on the passenger side, would tend to creak (squeak/etc)
2012 IS F Blue IS F Sport
2006 Mustang V6 wannabe
Old 03-26-2007, 11:33 PM   #6
Kiljosh's Avatar
Is this something I should take care of right away? ie is it dangerous? I dont exactly have 400 bucks for the bullitt kit.
Old 03-29-2007, 08:09 PM   #7
I_luv_HP&trq's Avatar
Send a message via AIM to I_luv_HP&trq Send a message via MSN to I_luv_HP&trq
have a friend turn the steering wheel lock to lock while you listen and feel with your hands if anything is vibrating. My inner tie rod end sqeaks like hell on every bump and turn i make
99 Cobra: flowmasters, 18x9.5 cobra R's, soon to be tuned and geared. daily driver
99 V6:in avatar, Mac Cai, true duals/flowmaster 40's ,UDP, custom tuned, bullitt suspension 18" wheels...taken by mother nature
I_luv_HP&trq is offline   Reply With Quote
Old 03-29-2007, 08:37 PM   #8
you shouldnt turn your wheel all the way to lock and hold it there
Old 03-29-2007, 09:10 PM   #9
MonteCitan's Avatar
That's not what he said though
Hey kiljosh I just realized it was you that made this post...
We need to meet up, and diag your car for ya...
Old 03-31-2007, 07:24 PM   #10
Kiljosh's Avatar
Dude if I were to meet you and have you diagnose my car you would pick it apart slowly and reveal problems I didnt even know I had.
I guess it couldnt hurt though, you can maybe tell me if you think it is my timing chain or lifters that are ticking too.
« yoyo | Knocking 3.8 »
Aftermarket steering wheel jch_1120 Pre-2005 V6 Mustang 7 04-13-2010 08:34 AM
aftermarket steering wheel JerryK123 1996-2004 Mustang GT 6 03-22-2010 12:59 PM
steering wheel please help?!?! rello Pre-2005 V6 Mustang 14 08-01-2009 06:07 PM
What steering wheel is this? HotRod.riguez Mustang Audio & Video 5 11-28-2006 09:19 AM
Steering Wheel natebest2000 Mustang Audio & Video 7 02-16-2005 12:22 PM
02:24 AM
