98 3.8 Transmission Issues - Mustang Evolution
Old 09-05-2010, 03:55 PM   #1
Question 98 3.8 Transmission Issues
Need some help. Just put in a remanufactured long block in my 98 stang and figured while I had the tranny out I would drain the fluid & replace the filter (all 12.5 qts). All seemed to go well but when I buttoned it all back up and went for a short test drive, the tranny shifted late and hard from 1st to 2nd and the O/D off light started flashing and the check engine light came on. Back to the shop put the check engine tool and got codes P0720 P1900. Said the speed sensor was bad. I replace the speed sensor on the back drivers side of the tranny. Long, short, same problem.
When I went to my local Advanced Auto Parts and ask which fluid the 98 3.8 required, they said Mercon V., so thats what I used. Digging around in different places looking for possible causes of the flashing O/D light I check in my Haynes manual and the manual called for Dex/Merc fluid on 94-98 and Mercon V for 99 on.
Now the question after all that is, Is it an issue to use Mercon V on the 98 and if so , is it the likely cause of the flashing O/D light.
Looking forward to ya'lls insight
Dmozilla is offline   Reply With Quote
Old 09-07-2010, 12:38 AM   #2
Re: 98 3.8 Transmission Issues
Witch sensor did you change? If you changed the one on the back of the tranny by the driveshaft that was the wrong one, there is a speed sensor right above the shift linkage that is the one you need to change. My stang when i bought it shifted real hard from 1 to 2 like it had a shift kit also the check eng light was on, after yelling at parts store employees for two days i found the right part and installed it reset the computer and everything worked good.
Straublittleman is offline   Reply With Quote
Old 09-07-2010, 11:15 AM   #3
Straublittleman
Thanks, The connector had come unpluged on
that sensor when I was putting the motor/transmission back in. Couldnt see it, but I could feel it once the
tranny cooled. You are the Man.
Old 09-07-2010, 11:16 AM   #4
Thumbs up Re: 98 3.8 Transmission Issues
Old 09-07-2010, 03:54 PM   #5
Glad I could help
Transmission issues!! topless91gt 1979-1995 Mustang GT 4 06-09-2007 03:58 PM
Issues with 03 GT 03YellowGT 1996-2004 Mustang GT 7 12-05-2005 10:57 AM
So I have some issues... bluemustang The Bar 14 02-21-2005 04:13 PM
Transmission Question: 1997 V6 Automatic Transmission ?? svtmustang88 Pre-2005 V6 Mustang 4 12-09-2003 04:49 PM
I have serious issues n8r The Bar 23 10-17-2003 12:33 PM
07:06 PM
