Need help replacing thermostat - Mustang Evolution
Old 04-01-2007, 01:31 PM   #1
I'm troubleshooting a coolant leak that appears to be coming from the thermostat gasket. I've drained the cooling system, removed the top hose, and removed the left (facing the car) bolt. The right side bolt is really tight and the 8mm nut head on it is starting to strip. I've lubed it with WD-40 and let set overnight...
Any advice on this? I would rather not take off the big pulley assembly (power steering and alternator). I am a skilled former motorcycle mechanic but cannot get to the bolt to put an impact driver on it.
Thanks for your advice.
floridamba is offline   Reply With Quote
Old 04-01-2007, 06:30 PM   #2
Re: Need help replacing thermostat
Well I got the second bolt out.. it had some water scale on it. The thermostat housing/neck had some corrosion on the bottom half of the sealing area and this was letting the pressure blow through.
I will check with the dealer tomorrow to see what a replacement costs.
Nasty thermostat problems.. 96GTMustangMark 1996-2004 Mustang GT 5 04-06-2009 04:00 PM
thermostat? ryanxup Pre-2005 V6 Mustang 3 11-27-2006 08:17 AM
Thermostat 97conv6 Pre-2005 V6 Mustang 18 06-13-2005 06:41 PM
thermostat housing Warfire80 1996-2004 Mustang GT 14 09-16-2004 11:00 AM
Thermostat Laser02 Pre-2005 V6 Mustang 14 07-08-2004 02:08 AM
06:55 PM
