04 Mustang v6 3.9L wont start - Mustang Evolution
Old 04-02-2007, 09:59 AM   #1
Ok...here is the deal...I think I have gremlins in this car.
It was running great...no problems....just got it used 4 weeks ago.
First things...dont really know if this has any bearing, but when I fill up the gas tank it wont shut off the pump and squirts out...Now I know how to fill a gas tank and have never had that problem......
Now...on to the symptoms that happened this weekend. First off, my girlfriend went to move the car and couldnt get it started....She said that the gas pedal was completely on the floor and nothing was happening....I went and tried and it was as if the pedal was disconnected. So I opened the hood and there was a load of slack more than 3 inches in the cable. What to do? Had no idea...did some reading and found out that sometimes it helps to put some spacers in..sounded like a good idea...(oh yeah we tried jumping the car first to see if it was a battery problem....it wasnt)
Now the next day...and this is where the gremlins come in...we go out and the gas pedal is back to normal...still...nothing. It sounds like it is going to turn over, but there is no gas...no smell of gas nothing...checked the fuel filter and it looks fine....has metal connectors and I dont have the tools to take it off...however the little switch in the trunk for the shut off (I think) the one that they tell you to reset...well it was pushed in and I had to manually unclick it...could that be the problem????
My guess is this....there is no gas getting to the engine..but I am not sure why? I live out on the Navajo Reservation and it would cost a bundle to have it towed...any suggestion on what to check?
Please help!!!
mammadawn is offline   Reply With Quote
Old 04-02-2007, 10:34 AM   #2
Re: 04 Mustang v6 3.9L wont start
as you turn your key to the on position after you put it in the ignition you should hear you fuel pump cut on (you can hear it from behind the car where the gas tank it, its a little whine that goes away after a sec or so when you turn the key on even if you dont start the car) do you hear this? If not its the fuel pump.
You shouldnt have to use the gas petal at all to start the car, just the brake, and push the clutch in if you have one.
Thats another note, there is a switch that you have to have the brake/clutch pushed in to start the car this may not be working. If you pushed the button in the trunk then the fuel filter wont come on I dont think, you have to turn it back on by pushing it again~
Old 04-02-2007, 10:37 AM   #3
Ok..it does make the sound in the back of the car. I always use the brake and clutch to start. Where would that switch be?
Old 04-02-2007, 10:41 AM   #4
its on the clutch if you look under there you can see it if memory serves me right. I think its pretty easy to find back behind the petal. The issue with the clutch petal is that the quadrent is over on the other side of the brake petal so it is kind of hard to trace around~ I think the switch is under the petal itself though. It shouldnt be to hard to find you can push in the clutch and look for it. You also have to have the brake pushed in as well.
Old 04-02-2007, 10:43 AM   #5
In a manual you need to press the brake to start? Man, I must have a defective car then. lol
Old 04-02-2007, 10:44 AM   #6
yea true... I am thinknig about an auto I just do it as habbit I guess.
Old 04-02-2007, 10:45 AM   #7
Uhm..no...not in an auto either...
I don't have to push any pedals to start my car or truck...
Old 04-02-2007, 11:01 AM   #8
Stumpy's Avatar
all i have to push is the unlock button on my remote. then i climb in, stick the key in the ignition and turn it until the car starts. so i guess mine must be defective too.
~Roman~
2003 Mustang V6 Vert with a Flowmaster Super 40 series dual exhaust
I'm not a target in the sights of your mercy. I've never asked for anything. I'm not asking now.
Stumpy is offline   Reply With Quote
Old 04-03-2007, 09:07 AM   #9
ok I will look under the clutch pedal for the switch.....
If the button in the trunk is depressed and you have to unclick it ie: by sticking something in the little slot I am assuming that there may be something wrong there....however, would it still not reset everything? Still not working....I was suppose to have someone look at it yesterday but he never showed....so I have this nice pretty car that goes really fast sitting half way down my driveway...
I always use the brake pedal if I am on a hill...even though I have the emergency on...and yes some auto's you do have to press in the brake in order to start it...Not that weird!
Old 04-03-2007, 09:09 AM   #10
Where are you located?
Old 04-03-2007, 09:22 AM   #11
I am in Navajo NM....they want to charge me $135 to tow it to a goodyear place that I am not even sure can deal with it!
Old 04-03-2007, 09:27 AM   #12
Hmm...that is a little far for me to cruise over and check it out.
Old 04-03-2007, 09:33 AM   #13
will the fuel pump still cut on if he has the button pushed wrong in the trunk? I always thought it simply would not turn on.
Old 04-03-2007, 09:38 AM   #14
I don't believe so. I believe that is the fuel pump kill switch...so it is dead when it is off.
Old 04-03-2007, 09:40 AM   #15
Not a problem....I tried to find a switch under the clutch pedal...there is a plug which seems fine....we have terrible pot holes or should I say lakes in our roads plus speed bumps..I have checked every conceivable plug there is ... it getting power and want to turn over, but no gas......just am at a loss.....is the switch in the trunk suppose to be down or up...it clicks but I am not sure it is resetting anything.....
Old 04-03-2007, 09:44 AM   #16
I can't answer that off the top of my head, but I will check mine at lunch and let you know. I believe it is supposed to be up though.
Old 04-03-2007, 09:49 AM   #17
Thanks....this is so frustrating....when you know why it wont start but cant do a thing about it.....
95 mustang wont start, ignition problem? Billy95Gt 1979-1995 Mustang GT 5 07-29-2010 09:03 PM
Help It Wont Start... kack85 Pre-2005 V6 Mustang 5 07-28-2009 07:14 AM
wont start !!! too fast Pre-2005 V6 Mustang 7 04-24-2009 07:26 AM
wont start???? bluestang1724 1979-1995 Mustang GT 11 01-04-2008 09:10 AM
wont start joezappitella 1979-1995 Mustang GT 5 12-04-2007 08:17 PM
06:15 PM
