gears - Mustang Evolution
Old 09-08-2010, 08:21 PM   #1
i<3ford's Avatar
gears
i want to get gears for my v6 96' stang. i want to go with the 3.73. what else is completely neccisary with the gears to buy. americanmuscle is telling me to buy like 10 things.
i<3ford is offline   Reply With Quote
Old 09-08-2010, 08:21 PM   #2
i<3ford's Avatar
Re: gears
also do the gears have to be 7.5 for a v6 or do i want 8.8
Old 09-08-2010, 08:38 PM   #3
obxdude018's Avatar
Re: gears
V6 mustangs have the 7.5 rear end and gt's have 8.8 rear end, as far as stuff that is needed if your car has over 60K get the bearing kit I believe it is 74.99 from AM, also it's not necessay, but an excellent upgrade is a traction-loc, but once again you don't need that to change gears
obxdude018 is offline   Reply With Quote
Old 09-08-2010, 08:51 PM   #4
i<3ford's Avatar
Re: gears
so don't buy 8.8s. i cant find traction-loc for 7.5
Old 09-08-2010, 09:00 PM   #5
obxdude018's Avatar
Re: gears
No don't buy the 8.8, the traction loc gives the car the ability to apply power to both rear wheels instead of your normal one tire burn-out, here is the link Ford Racing 7.5" 28 Spline Traction - LOK Limited Slip Differential at AmericanMuscle.com - Free Shipping!
Old 09-09-2010, 07:56 AM   #6
Re: gears
for gears buy ford racing if you can find them as they are least likley to whine. Motive and Richmond are known to be great gears, they just whine more.
Dont buy used, buy a traction lok with gears as its the same basic amount of work.
By the time you sum it all up you can probably find an 8.8 GT rear end with 3.73 gears already in it (with tlok unit) for around the same price.
the 7.5 rear end you have now is ok but weak if you plan to EVER take it to the track. They are known for breaking Tlok spider gears very easily... so that in itself would be the reason I would go with an 8.8 rear end.
94-98 and 99-04 both work fine but the 99-04 sticks out a tad more (like.75 inches per side)
Old 09-15-2010, 06:08 PM   #7
racefan966's Avatar
Region: Idaho
Re: gears
Find Tom's Differential he has Trac Locks for 7.5's.
racefan966 is offline   Reply With Quote
NEED HELP WITH GEARS!! Motive 4.10 gears? Cant find ford racing? Camaro Eater Pre-2005 V6 Mustang 4 06-23-2010 10:57 AM
3.73 gears tim11 Pre-2005 V6 Mustang 5 10-25-2005 08:21 AM
4.10 gears powerhungry966 Pre-2005 V6 Mustang 7 10-23-2005 06:53 PM
gears 8.8 or 7.5 strike1980 Pre-2005 V6 Mustang 5 07-31-2005 11:05 PM
Factory Gears Vs. Racing Gears tire Pre-2005 V6 Mustang 0 07-21-2003 04:02 AM
02:57 PM
