94-95 v6 owners - Mustang Evolution
Old 09-08-2010, 10:20 PM   #1
Talking 94-95 v6 owners
This is to all 94-95 v6 mustang owners if you were having trouble finding a tuner for your car I have finally found one that will work.
SCT X-Calibrator Version 3 from VPN TUNING
You can get special tunes and tuner for around $425 if you are looking into puting a procharger, turbo, or the M90 swap!
I hope this helps anybody out there because i've been looking everywhere. Also don't get mad when you see that it says v6 mustang 96-98, It does work on the 94-95 models to.
Straublittleman is offline   Reply With Quote
Old 09-09-2010, 07:58 AM   #2
Re: 94-95 v6 owners
yea also check with VMP tuning he is very well known in the V6 world.
Old 09-09-2010, 10:53 PM   #3
Re: 94-95 v6 owners
Yeah he is awesome, I will be ordering mine in a couple months then I will be installing the supercoupe motor and maybe stroking it to the 4.2L
Old 09-15-2010, 02:54 AM   #4
Re: 94-95 v6 owners
And it will definitely remove the speed limiter?
MERT is offline   Reply With Quote
Old 09-15-2010, 07:45 AM   #5
Re: 94-95 v6 owners
you can get more power from an 03/04 cobra supercharger setup vs a supercoupe setup FYI, or a single turbo for that matter.
Old 09-15-2010, 09:24 AM   #6
Re: 94-95 v6 owners
Speed limiter? I've had mine past 120mph already and its stock, when does the speed limiter kick in?
Old 09-15-2010, 09:27 AM   #7
Re: 94-95 v6 owners
Yeah it might have more power but as of right now i'll have $425 in the motor swap just because I have to buy a tuner
Old 09-15-2010, 11:17 AM   #8
Re: 94-95 v6 owners
when the car was stock it would speed limit to 112mph. I changed the rear ratio from 2.73 to 3.45, corrected the speedo with a 23 tooth speedo gear on the sender. the car now tops out at 86mph@2600rpm in OD, turning off the OD raises the rpm, but still topping at 86mph. Went to Brenspeed, got the SCT Eliminator chip that piggy backs the ECM, I saw a performance gain; but the limiter was still there. After three reflashes and no luck, I returned the chip for a refund. They said that '94 and '95 v6's were oddball years. I thought about using an ECM out of a '98 to see if it would work. Any ideas?
Old 09-15-2010, 11:35 AM   #9
Re: 94-95 v6 owners
speed limiter on 94-98 is rpm limited, if you install gears it will cut off about 86mph as you said due to rpm limit~ I thought there was some way to bypass the rpm limiter though
Old 09-15-2010, 04:20 PM   #10
Re: 94-95 v6 owners
There has to be because mine doesn't have a limit. I still have the 2 73 gears in it for now and I can "peg" the speedo, I've had mine around 125-130 I'd say because it only reads 120 and the needle was past that.
Old 09-15-2010, 04:24 PM   #11
Re: 94-95 v6 owners
Also I forgot to mention mine was 5-speed and one the owner's before changed it to auto. Don't worry though I'm going back 5-speed.
Old 09-16-2010, 01:54 AM   #12
Re: 94-95 v6 owners
One of the things the Eliminator chip did do was raise the rev limiter beyond 5000rpm (free spin) and when it was in drive(3rd) it topped at 86mph@3500rpm. If you guys could look into it, I would appreciate it. I've also talked to Diablo Sport and Ford Racing with no luck. I would try a handheld tuner, if I knew it would work. If only it were as easy as cutting a wire at the ECM.... Hey Straub, when they changed it from a 5 speed to an auto; did they put in an AOD trans or an AODE trans? And did they change the ECM at all?
Old 09-16-2010, 02:38 PM   #13
Re: 94-95 v6 owners
They did put in the aode trans i'm going to check the numbers on ecm to see if they changed it.
Old 09-16-2010, 03:10 PM   #14
Re: 94-95 v6 owners
Ok my ecm number is F4ZF-12A650-GD C4J3 with calibration number 4-15e if that helps any it is the stock 5-speed computer.
Old 09-17-2010, 10:06 AM   #15
Re: 94-95 v6 owners
Thanks for checking. Odd how the stock 5 speed computer would run the AODE with all the electronics in it. I may try a 5 speed ECM to see what it will do on mine. If you hear anything else, please let me know.
Old 09-17-2010, 12:15 PM   #16
Re: 94-95 v6 owners
No problem, I figured they would've changed the ecm but you could tell it has never been out of the car until i unbolted it. It had dust and dirt from way back
Owners Manual andyO Pre-2005 V6 Mustang 1 07-17-2008 06:40 PM
All FoxBody Owners in Here bluemustang Mustang Audio & Video 8 04-26-2007 01:43 PM
2004 Owners Herbstang The Bar 14 09-07-2005 11:26 AM
Insurance on 99+ GT owners under 25? timpryor The Bar 22 04-04-2005 03:58 PM
94+ owners please read Bane- Mustang Audio & Video 17 01-18-2005 08:54 PM
12:06 PM
