Clutch noise - Mustang Evolution
Old 09-09-2010, 11:08 AM   #1
Clutch noise
I have a '98 Mustang, 3.8L Std. There is noise coming from the clutch that stops once the clutch is depressed approximately an inch. Kind of chirping noise. No noise when clutch is depressed more than the one inch. Noise is present in all gears, all speeds.
jldusza is offline   Reply With Quote
Old 09-09-2010, 01:49 PM   #2
Re: Clutch noise
its your throw out bearing going bad, if you are going to replace it (cheap part) you have to take the transmission out (not cheap) so while at it replace the entire clutch setup.
Its not going to die over night, you have life left in it, just a matter of time though~
Old 09-12-2010, 01:26 PM   #3
shipwreck_98's Avatar
Re: Clutch noise
You shouldnt have to replace the entire clutch assembly. If your mileage is still pretty low on a factory clutch, its cheaper just to replace the throwout bearing. But while you are in there look at everything especially the pressure plate fingers and see how it is holding up. If you have the money to throw at it, go ahead and replace it all with what you want to put in. I replaced my throwout bearing a couple of months ago, had the same issue, loud screeching told me it was definitely time to replace it, havent had any issues since.
shipwreck_98 is offline   Reply With Quote
Old 09-14-2010, 07:50 PM   #4
racefan966's Avatar
Region: Idaho
Re: Clutch noise
Throw out bearing making noise get a performance Zoom kit you will like it but you will be replacing the bearing either way.
racefan966 is offline   Reply With Quote
Old 09-15-2010, 07:47 AM   #5
Re: Clutch noise
do not use a non ford throwout bearing, dont do it (I repeat dont use a non ford throwout bearing)
Old 09-15-2010, 03:27 PM   #6
racefan966's Avatar
Region: Idaho
Re: Clutch noise
Agreed
Old 09-15-2010, 03:53 PM   #7
SaleenFiend's Avatar
Re: Clutch noise
Mine died over night. I heard a chirp at like 6PM on my stroll home. The next morning at 6PM it was all she wrote. As soon as the car started I felt the shear terror of that screaming noise at 6AM...as did all my neighbors.
Old 09-16-2010, 07:17 AM   #8
Re: Clutch noise
Isnt that the most awful noise?! I felt like my fillings were about to explode in my head. I was so glad that it happened to me at the end of the week so I had plenty of time to mess with my transmission. The bell housing kicked my a$$!
strange clutch noise R1CK3R Pre-2005 V6 Mustang 10 10-02-2009 10:47 PM
Clicking Noise kind of Squeeky Noise... braumab 2005-2010 Mustang GT 23 06-29-2008 11:24 PM
No, seriously weirdest noise ever... Drunken Ghost Pre-2005 V6 Mustang 9 06-09-2006 04:52 PM
wierd noise InVaDeR Pre-2005 V6 Mustang 16 09-21-2004 05:31 PM
Noise when I reverse!!!!!! latinimagexx Pre-2005 V6 Mustang 3 04-16-2004 06:44 PM
10:54 PM
