Voltage stabilizer + gas saver - Mustang Evolution
Old 09-09-2010, 11:36 PM   #1
Question Voltage stabilizer + gas saver
I was wondering if this was a piece of crap or if it really works. I'm sorry if anybody has posted the same thing but I haven't seen it. Here is the link not sure if I did it right but you should be able to copy/paste it.
FORD UNIVERSAL JDM VOLTAGE STABILIZER BATTERY/GAS SAVER: eBay Motors (item 170537970855 end time Oct-08-10 20:52:03 PDT)
Straublittleman is offline   Reply With Quote
Old 09-10-2010, 11:11 AM   #2
DarkShadows's Avatar
Re: Voltage stabilizer + gas saver
No no no.
March 2010 Mustangevolution Mustang of the Month 1st eva biatch!
DarkShadows is offline   Reply With Quote
Old 09-10-2010, 01:39 PM   #3
So? Does that mean it's a p.o.s I figured it would be, just wondering if it's some kind of a capacitor that would help with stereo drain or if its just a fancy box with wires?
Old 09-10-2010, 01:53 PM   #4
Its a piece of crap
Old 09-10-2010, 01:57 PM   #5
Ok thanks guys just figured i would run it by you all. thanks
Old 09-15-2010, 06:48 PM   #6
racefan966's Avatar
Region: Idaho
Don't do it.
racefan966 is offline   Reply With Quote
Old 09-18-2010, 09:19 AM   #7
gwbarton7's Avatar
question to the group my 2004 seems to have a severe power drain. I have replaced the battery every year for the last three replaced alternator two years ago. last week i put a new battery in and everytime I use the AC it drains it down whats up
gwbarton7 is offline   Reply With Quote
Old 09-21-2010, 01:59 PM   #8
SaleenFiend's Avatar
Bad ground? Faulty electronic device causing a parasitic drain?
Old 09-22-2010, 10:48 PM   #9
I agree with saleenfiend take your altenator off and clean the contact points "meaning where the bolts screw in at" with sand paper the altenator might not be getting a good ground. It wouldn't hurt to put an extra ground wire running off one of the altenator bolts to the negative of the battery.
Old 09-22-2010, 10:55 PM   #10
Not exactly what I was saying. There are random multiple different electronics throughout the car that depend on different grounds to help complete circuits within the electronics. Usually requires and electronic diagnosis if that's in your neck of the woods.
Fuel Saver and Turbo Tip andyxc Pre-2005 V6 Mustang 2 04-17-2008 12:56 PM
low voltage calvin6199 1979-1995 Mustang GT 5 04-10-2008 07:51 AM
voltage regulator white 98 gt 1996-2004 Mustang GT 3 08-30-2006 04:00 PM
irregular voltage to the air filter mustangruss Pre-2005 V6 Mustang 5 11-21-2005 04:32 PM
05 screen saver whipster24 The Bar 2 11-06-2003 05:53 PM
04:06 AM
