OBDII port not working - Mustang Evolution
Old 09-14-2010, 09:13 PM   #1
Hi again everyone I have a problem with my obd II port not registering with my inova 3100 code reader. I have a 94 3.8. does anyone know which pins to test for voltage to make sure it's getting power? i've checked the fuses and they are good.
Jallath is offline   Reply With Quote
Old 09-14-2010, 10:18 PM   #2
Re: OBDII port not working
Well since I seem like the only one on here that will answer your questions Did you clean the port with alcohol & Qtip. If all else fails I'll test my port and tell you wear the hot and grounds are.
Straublittleman is offline   Reply With Quote
Old 09-14-2010, 11:10 PM   #3
actually I didnt think to clean the contacts :S some engineer i'll be lol. I'll give that a shot tomorrow. If i had to i could do a continuity test between battery terminals and pins but i don't have probe wires long enough for that lol. Hope its just dirty, if it's as dirty as the rest of the car was when i got it i'll need more than alcohol lol.
Old 09-15-2010, 05:21 PM   #4
racefan966's Avatar
Region: Idaho
Here is how to do it with a paper clip and test light ok. So take the paper clip and jump from the single test connector to term 2 on the larger connector. Now the test light from the possitive side of battery to term 4 on the larger connector. Now turn the key on and count the blinks on the test light. Now if you don't have the means to look up the codes let me know I have Mitchelle on Demand. By the way 94 should be OBD 1 as 96 was the first OBD2
racefan966 is offline   Reply With Quote
Old 09-15-2010, 06:19 PM   #5
I'm sorry but the 3.8L V6 94-95 is OBD-2. The 5.0's are obd1
Old 09-15-2010, 06:21 PM   #6
the test port under the hood of the v6 is for ABS brakes. I have a factory service manual for the 94's
Old 09-15-2010, 06:28 PM   #7
racefan966's Avatar
Region: Idaho
Thats right sorry my bad, I will look up on Mitchelle later and tell you which term gives power to the scan tool ok.
Old 09-16-2010, 10:41 AM   #8
racefan966's Avatar
Region: Idaho
Ok use the chart included to check that there is a good ground and that there is power where needed. Hope this will help. [IMG]C:\Users\The Sargents\Pictures\2008-06-22 Pics 2008\Ebay[/IMG]
Old 09-16-2010, 10:47 AM   #9
racefan966's Avatar
Region: Idaho
If you can't see the image then get me your e-mail and I will send it to you ok.
Old 09-17-2010, 10:55 PM   #10
Did you get the code reader to work?
Old 09-21-2010, 10:51 AM   #11
SaleenFiend's Avatar
Check the wiring into the OBDII unit as the pins seem to back out of place sometimes. Your power pin may be loose.
Old 09-21-2010, 08:49 PM   #12
racefan966's Avatar
Region: Idaho
Did you get the pic of the test port for testing?
Old 09-28-2010, 05:59 PM   #13
I did not get the image, and so have far have yet to get the port working. School work got piled on for the last few weeks but I have a week off now so I'm back to fix this problem. it would be great if you could email me that image my email is jallath.veldahar@gmail.com
Old 10-05-2010, 01:59 PM   #14
I have confirmed by extensive continuity and voltage testing that the port is not getting power.. i have checked the fuses and none are blown.. going to try them out in a fuse tester one by one to make sure there is no problems with them.
single port or split port 97 stang Pre-2005 V6 Mustang 8 10-10-2008 06:51 PM
single port to split port conversion NorwegianMustang Pre-2005 V6 Mustang 3 06-19-2006 03:19 PM
My terminology for single port and split port RGR Pre-2005 V6 Mustang 0 01-03-2004 10:03 AM
04:45 AM
