T-Lok and rear end gears - Mustang Evolution
Old 04-18-2007, 12:35 PM   #1
Winger's Avatar
This is gonna be the first mod aside from exhaust that i'm gonna do, and i need a good link to a place someone KNOWS is good to buy a traction lock and a 4.10 gear (automatic). and how much should i expect for an install?
also, when i'm looking for 3.9 parts, might i just as well look for 3.8 parts? are they practically the same?
2004 V6 3.9L
Winger is offline   Reply With Quote
Old 04-18-2007, 12:37 PM   #2
Re: T-Lok and rear end gears
go ford racing for gears and tlok dont buy richmond or any of that crap, just oem ford.
for the install it will range any where from 200-400~ and pay more to get the job done better as its a nightmare when the rear end gets messed up and its not hard to screw up a gear install.
Old 04-18-2007, 12:44 PM   #3
Winger's Avatar
t-lok and gear look good? so i'm looking at probably $700 for both bought and installed?
and on the T-Lok, it says "REQUIRES 4 OZ. OF FRICTION MODIFIER ON INITIAL FILL. 28 SPLINE 7.5" FOR V6 MUSTANG. " what does that mean? and how do i get the 4 oz. friction modifier?
and is my mustang by stock default a 7.5"?
2004 V6 3.9L
Old 04-18-2007, 01:04 PM   #4
I_luv_HP&trq's Avatar
Send a message via AIM to I_luv_HP&trq Send a message via MSN to I_luv_HP&trq
yes you have a 7.5" rear. Friction modifier can be found at any parts store.
Just curious, why did you decide to go with the 4.10 gears?
99 Cobra: flowmasters, 18x9.5 cobra R's, soon to be tuned and geared. daily driver
99 V6:in avatar, Mac Cai, true duals/flowmaster 40's ,UDP, custom tuned, bullitt suspension 18" wheels...taken by mother nature
I_luv_HP&trq is offline   Reply With Quote
Old 04-18-2007, 01:09 PM   #5
Herbstang's Avatar
Your also gonna need a SCT chip or recalibrator to correct the speedo
Old 04-18-2007, 01:11 PM   #6
Winger's Avatar
says 4.10 for automatic in When Modding a Car from the Start.
2004 V6 3.9L
Old 04-18-2007, 01:13 PM   #7
yea the auto tranny has worse gearing when compared to the manual so 4.10 help even it back out and they need all the help they can get.
friction modifier is easy to get and cheap
Old 04-18-2007, 01:18 PM   #8
Yea I knew that was the reason but I wanted to ask anyways. Just want you to be sure of everything that you're getting in to.
I don't know if your car is a dd or not but your gas mileage may go down with highway driving.
Your RPM's will be about 500 more then if you had your stock 3.27.
You may already know this but I just wanted to make sure because when I was new at all this I just went ahead with what everyone else said and took their word for it, which i shouldnt of done.
Old 04-18-2007, 01:20 PM   #9
Winger's Avatar
and i dont have enough money to get the tlok, gears, and a speedo recalibrater. would i need that just cause of the gear? and how much speed difference are we talking from the reg speedo?
2004 V6 3.9L
Old 04-18-2007, 01:21 PM   #10
You will also see a slight increase in mpg in the city because you will be in your power band sooner for cruising.
If you are worried about gas mileage you really don't want to mod your car. But..actually...I get 28-30 on the highway in my car how it is right now.
Old 04-18-2007, 01:29 PM   #11
I just didn't want him to get everything installed and spending all his money, then all of a sudden wonder why the hell his RPM's are at 2600 cruising down the freeway.
I think some people don't fully understand the side affects of everything that they want to do to their cars performance.
Old 04-18-2007, 01:30 PM   #12
Winger's Avatar
i appreciate that.
2004 V6 3.9L
Old 04-18-2007, 01:33 PM   #13
It's cool.
If you are looking for a cost efficient seat of the pants improvement, you can't beat gears.
As far as your speed difference, your rear tires will be turning over 4.10 times for every one revolution of your driveshaft. Factory, your tires are turning over 3.27 times for every one revolution of your driveshaft. This will cause your speedometer to read a slower speed than you are actually going. As far as an exact speed, I can't tell you an exact measurement.
Old 04-18-2007, 01:45 PM   #14
Winger's Avatar
like enough to get me a speeding ticket?
2004 V6 3.9L
Old 04-18-2007, 01:46 PM   #15
It would probably read 6-7 mph slower if you were doing highway speeds. If you can't afford a chip or tuner right now and want to get the gears, get them installed and have a friend follow you to see how much your speedometer is off. Once you figure this out you can learn how fast you need to be reading to do the speed limit and such.
Old 04-18-2007, 01:49 PM   #16
Winger's Avatar
6-7 isnt really that bad, thought you mean maybe like 15.
so anyways.
t-lok and 4.10 gear, + 4 oz friction modifier + installation = $700?
2004 V6 3.9L
Old 04-18-2007, 01:53 PM   #17
Depends on where you get it installed.
I'd shop around to see who had the best price on install with a warranty.
Old 04-18-2007, 01:55 PM   #18
Winger's Avatar
thought you meant like 15... 7 isnt really that bad.
so
tlok+4.10+4oz friction whatever+instal = $700-800?
2004 V6 3.9L
Old 04-18-2007, 02:00 PM   #19
Winger's Avatar
friction modifier?
thought it was an install piece lol... so i can probably self apply that then?
also, another question. When looking for stuff, i have a 3.9, can i look for 3.8 stuff cause 3.9 is sometimes not even an option.
2004 V6 3.9L
Old 04-18-2007, 02:03 PM   #20
Yes, you shouldn't run into an problems between the 3.9 and the 3.8.
Old 04-18-2007, 02:08 PM   #21
Winger's Avatar
did i link the right friction modifier stuff? its just lube not a part?
2004 V6 3.9L
Old 04-18-2007, 02:09 PM   #22
Stumpy's Avatar
even though it does have a windstar part on it. sorry, couldn't resist.
~Roman~
2003 Mustang V6 Vert with a Flowmaster Super 40 series dual exhaust
I'm not a target in the sights of your mercy. I've never asked for anything. I'm not asking now.
Stumpy is offline   Reply With Quote
Old 04-18-2007, 02:09 PM   #23
Winger's Avatar
we left that in the other forum you sonofa*****!!!!!!!
2004 V6 3.9L
Old 04-18-2007, 02:11 PM   #24
Stumpy's Avatar
2: now now. temper temper. no need for name calling. learn to take a joke.
~Roman~
Old 04-18-2007, 02:13 PM   #25
Winger's Avatar
we left that in the other thread you sonofa*****!!!!
2004 V6 3.9L
Old 04-18-2007, 02:16 PM   #26
Winger's Avatar
but is the 4oz friction modifier they talk about on the tlok page just a 4oz bottle of lube basically?
2004 V6 3.9L
Old 04-18-2007, 02:17 PM   #27
rydog's Avatar
Send a message via MSN to rydog
Yes its for the clutches in the t-lok
97 V6-GT40 turbo-42#rs-BA2800 MAF-4.10's & tlok-254rwhp-369rwtq
Turbo'd by-TMA Turbo(http://www.tmaturbo.com/)
Tuned by-Dyno Tuned Performance(http://www.dtpracing.com/)
rydog is offline   Reply With Quote
Old 04-18-2007, 02:22 PM   #28
Winger's Avatar
sorry bout the double posts... and i was jk about the sob comment. much love
2004 V6 3.9L
Old 04-18-2007, 02:23 PM   #29
Winger's Avatar
thx rydog for finally answering the question = )
2004 V6 3.9L
Old 04-18-2007, 02:30 PM   #30
Stumpy's Avatar
no worries.
~Roman~
Old 04-18-2007, 02:33 PM   #31
Yeh sorry, I headed outside for a few to get my new exhaust out of the truck.
Old 04-18-2007, 02:37 PM   #32
Scut95's Avatar
if someone he knows has the calibration tool can't he just borrow it and upgrade his computer to read the right speed?
Old 04-18-2007, 02:40 PM   #33
rydog's Avatar
Are you changing your exhaust again...lol
Old 04-18-2007, 02:44 PM   #34
No, because it won't touch your tune without locking itself to your car. It won't lock to a car if it is already locked in to another. The only way to unlock it is to restore your tune to stock...so, the only way he could give it back is to undo the changes he would make.
Old 04-18-2007, 02:49 PM   #35
get it calibrated else you will be commiting odometer fraud.
Rear End gears 2007STANG Pre-2005 V6 Mustang 19 03-23-2009 06:38 PM
Rear end gears ttpancakes Pre-2005 V6 Mustang 18 12-04-2007 07:26 PM
rear end gears o3mustangGTafs 1996-2004 Mustang GT 2 07-17-2006 08:42 PM
rear end gears?? chipshot101 1996-2004 Mustang GT 1 07-22-2004 08:05 PM
Rear End gears? RedDragonV6 Pre-2005 V6 Mustang 3 03-18-2004 03:12 PM
09:10 AM
