Speedo works, Odometer does not.. - Mustang Evolution
Old 04-22-2007, 05:07 PM   #1
On my '96 Mustang, the speedometer works great but the odometer stopped. I have no clue what is wrong - it seems like they would be using the same kind of system for both.
Can someone give me some ideas of what is wrong?
thanks!!!
floridamba is offline   Reply With Quote
Old 04-22-2007, 05:12 PM   #2
Re: Speedo works, Odometer does not..
The gear that turns the odometer is probably stripped out.
Old 04-22-2007, 06:23 PM   #3
Brent, thanks for the info. I checked out your pics - that is an awesome Mustang!! What kind of transmission do you have - I did not see it listed or didn't pick up on it. Mine's a 5-speed.
Question 1 - Is this a big deal to replace? No doubt I would have to put it up on jack stands. I've replaced the water pump so far, removed the plenum and one rack of injectors so far.
Question 2 - Is there an online web site where I can look at parts microfiche images online?
thanks
David
Old 04-22-2007, 06:33 PM   #4
Zim
You want to **** me?
Zim's Avatar
Shouldnt need to put it on jack stands... you'll need to remove your guage cluster, open it up, and check and see if something is stripped in there. Maybe even remove the cluster and take it to ford to have them do it. I dont know what it would cost though.
I like toys
Old 04-22-2007, 06:37 PM   #5
I was thinking it would be the drive gear in the transmission like used to drive speedometers before they changed to electronic.
Old 04-22-2007, 06:42 PM   #6
This is my thought as well.
There is a little plastic tooth gear in the sending unit in the transmission. It is probably stripped.
Old 04-22-2007, 06:53 PM   #7
Zim
Zim's Avatar
If it was that gear the speedo wouldnt work either. Unless Im retarded and there's two different gears in there. One for odometer, one for speedometer, but I figured it all ran on the same thing.
I like toys
Old 04-22-2007, 06:54 PM   #8
Ah, I read it wrong. I thought the speedo wasn't working.
So yeh, I'd say something in the dash.
Old 04-22-2007, 06:56 PM   #9
bummer.. maybe the odometer thingie is broken... I'll call my dealer tomorrow.
thanks
David
Old 04-24-2007, 03:02 AM   #10
matthews.stang's Avatar
DIY: Repair your broken Odometer & Tripometer - 3.8 Mustang Message Board
There ya go man. Complete walk through.
matthews.stang is offline   Reply With Quote
odometer 98mustang2007 Pre-2005 V6 Mustang 2 03-28-2008 04:14 PM
odometer not working 98mustang2007 1996-2004 Mustang GT 4 03-20-2008 10:25 AM
What to do when replacing Odometer? fast64 General Car Discussion 5 01-17-2008 08:52 AM
What does your Odometer read? DarkShadow General Car Discussion 54 06-18-2007 09:53 PM
Speedo/Odometer Gears floridamba Pre-2005 V6 Mustang 5 05-01-2007 08:32 AM
09:32 PM
