Somethings wrong in the rear end! - Mustang Evolution
Old 04-25-2007, 06:09 PM   #1
.red.pony.'s Avatar
Send a message via AIM to .red.pony.
Exclamation Somethings wrong in the rear end!
my mustang keeps making this weird noise that seems to be coming from somwhere in the rear. It's almost a whining noise, and i dont know if this has any connections to the whining noise, but when i come to a complete stop and let off the brake to go again, the car jolts or something...kinda hard to explain, but if anyone know whats im talking about and how to fix it i would appreciate your input!
.red.pony. is offline   Reply With Quote
Old 04-25-2007, 06:10 PM   #2
Re: Somethings wrong in the rear end!
Do you have a fluid leak in your rear making the rear end fluid low perhaps? This can cause some issues. You should be able to see if there is a leak by looking at the rear end cover.
Old 04-25-2007, 06:12 PM   #3
.red.pony.'s Avatar
Yeah i actually had my boyfriend check that about a week ago, it had plenty of fluid, and there didnt appear to be any leaks..
<a href=http://i104.photobucket.com/albums/m180/daniel1991_2006/Picture038-1.jpg target=_blank>http://i104.photobucket.com/albums/m...cture038-1.jpg</a>
Old 04-25-2007, 06:15 PM   #4
Don't worry to much as the rear end parts on your car are pretty darn cheap. If it happens to need new gears or something of that nature let us know and we can help you make a nice upgrade for the same price as replacing the oem parts.
You can try to jack the car up and spin the tires to see if you hear any sort of grinding noises but I doubt you will. You might be describing two different issues. Some 99+ v6s have gear whine in the rear end that lasts in a given mph/rpm range and then goes away. It is usually not constant just within a given range. If this is the case it wont break anything it is just an issue with the gear installation specifications.
The other issue you might have is the transmission, is it an auto or manual? If it is an auto there might be an issue with the tq converter~ this is of course just speculation.
Old 04-25-2007, 06:15 PM   #5
matthews.stang's Avatar
Bearing. How many miles on the car? How are the U-Joints?
matthews.stang is offline   Reply With Quote
Old 04-25-2007, 06:18 PM   #6
.red.pony.'s Avatar
It is an automatic...and im not even sure what u-joint is...lol the car has 85,000 miles on it.
Old 04-25-2007, 06:21 PM   #7
.red.pony.'s Avatar
nice car btw spectorV
Old 04-25-2007, 06:22 PM   #8
bbunt302's Avatar
Have you checked the rear calipers? They have a bad habit of seizing up on the 99-04 Mustangs. That could explain both your whine and the jolt.
Pull your rear wheels and take a good look at the rotors. If you see any grooves developing, you probably have a seized caliper.
Scary stuff.
Old 04-25-2007, 06:27 PM   #9
That is a really good point. Start with the easy to check items. Jacking the car up and turning the wheel will let you know if the caliper is messed up. The wheels should turn rather easy (it just wont turn without any force but its not to bad to turn). Your emergency brake could also be on a bit. It is just one of those things that you will have to investigate to find the cause. I am also thinking it might be the axle bearings.
Old 04-25-2007, 06:29 PM   #10
.red.pony.'s Avatar
alrighty ill have to get the boyfriend to check those things for me this weekend, thanks for all of ya'lls help!
Old 04-25-2007, 10:25 PM   #11
Stumpy's Avatar
i was leaning towards brakes as well. when you apply the brakes coming to a stop, does it go away? and when you back up and apply the brakes, does it make a weird buzzing sound? if so could be something as simple as rear pads being worn. just a thought.
~Roman~
2003 Mustang V6 Vert with a Flowmaster Super 40 series dual exhaust
I'm not a target in the sights of your mercy. I've never asked for anything. I'm not asking now.
Stumpy is offline   Reply With Quote
Old 04-26-2007, 06:58 AM   #12
.red.pony.'s Avatar
no it doesnt do the jolt thing until i let off the brake...
Old 04-26-2007, 10:49 AM   #13
Thomas91169's Avatar
does it make a loud audible moan as you creep away from the stop, and as soon as you get moving (around 1-2mph) it goes away? does it sound like every time you take off from a stop two pieces of metal are prying away from eachother?
if so, its the same thing i have and after new rear brakes im still stumped. if it was bearings, it should do it only after a given mph (like 50 and above). mine only does it under load, i cannot recreate the sound with the rear in the air.
however, the clunk leads me to believe its the U-Joints in the driveshaft. does it also make this clunk in reverse?
-Thomas-
Old 04-26-2007, 10:50 AM   #14
His isn't all that great.
Old 04-26-2007, 02:48 PM   #15
.red.pony.'s Avatar
it doesnt do the jolt thing in reverse, but sometimes when im in reverse it makes this loud grinding type sound or something...but it does only do the clunk thing when i take off then it stops...if you find out what it is let me know!
Old 04-26-2007, 02:50 PM   #16
.red.pony.'s Avatar
lol oh ur just jealous...
Old 04-26-2007, 03:01 PM   #17
ridenmystang's Avatar
I can prob tell you what it is....... the U joints. Mine was doing the same thing.
One wicked 03 GT FOBRA
ridenmystang is offline   Reply With Quote
Old 04-26-2007, 03:03 PM   #18
Stumpy's Avatar
you know, with the title of this thread phrased like it is, and the author being a chick, i am finding it really hard to control myself. and then Riden shows up on here and there are two chicks... must... find... control... the force... is too... strong.
~Roman~
Old 04-26-2007, 03:04 PM   #19
O lord......... Ok youve arrived...... raised hell......... now leave! haha jk!!!
Old 04-26-2007, 03:11 PM   #20
Stumpy's Avatar
hey, be nice. or i won't hump your leg anymore. i know, i know, don't get your hopes up. (don't worry, i'm lying.)
~Roman~
Old 04-26-2007, 03:12 PM   #21
Haha Doofus
Old 04-26-2007, 03:31 PM   #22
i gave up with mine. ill probably just take it into a shop and have them **** with it. it has me totally stumped, as well as everyone i know thats ever been in the car and heard the noise.
-Thomas-
Old 05-02-2007, 10:38 AM   #23
Tape's Avatar
One of your rear calipers is not releasing. I had the same problem with my right rear caliper ('03 GT) I had to blow them out and clean them. After that no more moan.
Tape is offline   Reply With Quote
Old 05-02-2007, 04:46 PM   #24
bullitt482's Avatar
Could you just have bled the brakes? /\
01 Bullitt
Old 05-02-2007, 05:24 PM   #25
.red.pony.'s Avatar
How do you do that?
Old 05-02-2007, 05:26 PM   #26
bullitt482's Avatar
Just buy a Hanes/Chilton manual for your car, it'll be in there.
01 Bullitt
Old 05-02-2007, 05:36 PM   #27
.red.pony.'s Avatar
thanks i'll give it a try!
Old 05-03-2007, 07:51 AM   #28
Tape's Avatar
yeah, it is a bit to explain but here's a similar example
Brake Bleeding -Purging air and moisture from your brakes
something is wrong with my rear end tim11 Pre-2005 V6 Mustang 3 07-02-2015 11:20 AM
97 v6 rear end 97 stang Pre-2005 V6 Mustang 1 10-09-2008 10:22 AM
New rear end? Pro501day Pre-2005 V6 Mustang 18 09-09-2006 09:55 AM
rear end v6stangracer Pre-2005 V6 Mustang 12 03-23-2005 09:41 AM
8.8 Rear End ttpancakes Mustang Parts for Sale and Wanted 8 07-20-2004 06:39 PM
09:43 AM
