'98 A/C Cluth Issue - Mustang Evolution
Old 05-01-2007, 03:40 PM   #1
matthews.stang's Avatar
'98 A/C Cluth Issue
Okay, so a few weeks ago I was driving down the road, and my A/C went out. Well, it's been a few years so I figured it needed some R134a. So I go buy a few cans, and my dad hooks up the system, and the A/C clutch wouldn't kick on. So we break out the test light, and we are getting power at the low pressure switch. On down the harness, we test the plug that is going into the A/C compressor, and guess what? No power what so ever.
So where do I need to start? I keep reading stuff about the CCRM, but I don't think that's it because I would have a lot of other problems as well if that was bad. Is there any other switch or relay before it reaches the compressor clutch?
matthews.stang is offline   Reply With Quote
Old 05-01-2007, 08:25 PM   #2
I_luv_HP&trq's Avatar
Send a message via AIM to I_luv_HP&trq Send a message via MSN to I_luv_HP&trq
Re: '98 A/C Cluth Issue
Just so I get the facts straight....Did you test it at the plug coming off the harness or the "female" end that it plugs in to?
Also is it possible that the coils in the compressor are worn to the point where it won't hold enough magnetism and kick in?
One thing I would try is to have the car running and using a long screwdriver or similar shaped solid object, push on the compressor and try to make it engage yourself. Now of course you dont want your face hovering over the compressor because if it does engage it can give your hand a bit of a kick.
If that doesn't work then maybe we can keep trouble shooting it and figure it out.
99 Cobra: flowmasters, 18x9.5 cobra R's, soon to be tuned and geared. daily driver
99 V6:in avatar, Mac Cai, true duals/flowmaster 40's ,UDP, custom tuned, bullitt suspension 18" wheels...taken by mother nature
I_luv_HP&trq is offline   Reply With Quote
Old 05-01-2007, 08:28 PM   #3
Yea, I grabbed a test lightm hooked it up to the negative end of the battery, and then test the female end that plugs into the A/C compress with the system on Max A/C and blowing all the way hight, it got no power.
Old 05-03-2007, 05:46 PM   #4
Bump. Anyone have any ideas?
tuneing issue? BaginDVS1 2005-2010 Mustang GT 18 06-08-2009 07:06 AM
Clearance issue? bobbyoooo 1996-2004 Mustang GT 3 01-23-2009 07:08 PM
speedometer issue.. MonteCitan 1979-1995 Mustang GT 3 08-15-2006 05:14 PM
need help with a serious issue Kyle The Bar 13 04-22-2005 07:48 PM
Getting The Last Issue Dan The Bar 7 01-14-2004 02:54 AM
05:08 AM
