Looking into buying a cam. - Mustang Evolution
Old 09-22-2010, 12:25 AM   #1
I was wanting everybodies opinion on buying this cam from comp-cams. do you think it's to much for the motor or should I go for it.
I will be installing it in a 3.8L supercoupe motor with less than 65,000 miles on it. If you all think it will work good.
Xtreme Energy(Tm); Camshaft: Hydraulic Roller; 1500-6000 Rpm; Advertised Duration 265 Intake/281 Exhaust; Valve Lift .500 Intake/Exhaust; Lobe Angle 115 Degrees
Straublittleman is offline   Reply With Quote
Old 09-22-2010, 11:25 AM   #2
SaleenFiend's Avatar
Re: Looking into buying a cam.
What other mods do you plan on installing on/with the motor?
Old 09-22-2010, 09:01 PM   #3
Nothing really some underdrive pullies, CAI, 10-15% overdrive pully on the supercharger and of corse better exhaust.
Old 09-22-2010, 09:56 PM   #4
What blower setup are you running?
Old 09-22-2010, 10:20 PM   #5
It's a stock thunderbird eaton m90 supercharger
Old 09-23-2010, 06:55 PM   #6
Does anybody have another suggestion??
Old 09-24-2010, 06:41 AM   #7
Imo. It seems a little too aggressive. Don't those engines peak in the high 4000 low 5000 rpm range? I would check out supersix motorsports for the right cam.
tigerfan2771 is offline   Reply With Quote
Old 09-24-2010, 02:24 PM   #8
Thanks supersix motorsports recommends
218/224 duration
.55/.55 lift
1.7 rockers
112 LSA
Old 09-24-2010, 02:33 PM   #9
218/224 duration
.55/.55 lift
1.7 rockers
112 LSA
Those specs seem a lot less radical than the previous
Old 09-24-2010, 05:30 PM   #10
Yes they do but thats what they recommend I just wonder how much it will make a differance with that cam? lobe lift stock is .245 intake & .259 exhaust not sure on the rest.
Old 09-24-2010, 06:07 PM   #11
Do you want this setup to be pretty streetable?
Old 09-24-2010, 06:12 PM   #12
Yeah but would like to be able to hear the cam lope a little. I don't want it to be extream or anything just sound good with added horsepower.
Old 09-24-2010, 07:28 PM   #13
I think you would be satisfied with this setup.
Old 09-24-2010, 07:28 PM   #14
although I don't know from experience.
Old 09-24-2010, 07:28 PM   #15
youtube v6 with cam
Old 09-25-2010, 12:34 AM   #16
Send a message via AIM to VCS_SSSTANG
The more recognizeable specs for this cam are. 210/225 .50 115 LSA its not a big cam at all.
VCS_SSSTANG is offline   Reply With Quote
Old 09-25-2010, 12:20 PM   #17
The thing is I can rebuild just about any motor you set in front of me but I have no clue about buying cams do you or anybody have a suggestion on what size cam would sound good but not kill drivability on the street.
Old 09-29-2010, 06:41 AM   #18
They have a cam on there site that is made for the loping sound without going extreme.
Old 09-29-2010, 11:47 AM   #19
If your talking about thumper cam from comp they only make it for the v8s that i've seen I could be wrong but havent seen it. If you're talking about supersix then only cam I seen they reccomend.
Buying staang Pre-2005 V6 Mustang 8 04-08-2010 05:08 PM
v6 to true exaust. buying parts. am i buying the right parts steveyb927 Pre-2005 V6 Mustang 4 04-16-2009 10:04 PM
3.8 V6 Comp Cam Performance Cam nmaraijko Mustang Parts for Sale and Wanted 0 11-15-2006 07:11 AM
Cam Cores needed for RDMotorsport cam GP RGR Mustang Parts for Sale and Wanted 3 03-05-2005 05:53 AM
08:55 PM
