hard to start - Mustang Evolution
Old 09-22-2010, 08:17 AM   #1
hard to start
My 03 v6 started acting up yesterday. After driving for a while you turn it off, and after 10/15 min it does not want to star, it turns and turns until it catches and it starts.
My battery is kind of old but, but it starts when cold.
Thank you all very much,
Jorge
jorge gonzalez is offline   Reply With Quote
Old 09-22-2010, 09:36 AM   #2
Re: hard to start
take the battery to get it tested, also test the alternator. If both are ok then you have a couple other areas
you need spark and compression, timing (of spark) my next stop would be spark
Old 09-22-2010, 10:34 AM   #3
SaleenFiend's Avatar
Re: hard to start
Lose ground, bad battery terminal connection?
Old 09-24-2010, 07:27 AM   #4
MonteCitan's Avatar
Re: hard to start
Does it crank normally, just doesn't fire? That's the key before checking for electrical issues..
If it cranks slow then yeah.. But sounds like it's just cranking and cranking..
2012 IS F Blue IS F Sport
2006 Mustang V6 wannabe
Old 09-24-2010, 08:43 AM   #5
Re: hard to start
Yea, for some reason I thought he said it was clicking the first time I read it... now that I have re-read it, it sounds like a fuel/spark.
Have your fuel pressure checked.
Check your compression in the cylinders.
Make sure your plugs are gapped correctly.
Have the car checked out for correct timing.
Check for correct operation of the distributor.
Old 09-27-2010, 10:59 PM   #6
DEG
Re: hard to start
Check for correct operation of the distributor.[/QUOTE]
how do u check your compression in the cylinders?
DEG is offline   Reply With Quote
Old 09-27-2010, 11:11 PM   #7
Re: hard to start
how do u check your compression in the cylinders?[/QUOTE]
You get a compression tester from any autoparts store and screw it into your spark plug hole and turn the engine over a couple of times but don't start it unplug your coil first then read the gauge.
Straublittleman is offline   Reply With Quote
would this be hard to do? PenguinFan Pre-2005 V6 Mustang 6 09-08-2009 08:24 AM
Breaking Up Is Hard to Do! My 5.0 jwyche 1979-1995 Mustang GT 27 02-17-2009 09:35 PM
04 GT hard start 4.6fox 1996-2004 Mustang GT 14 08-13-2008 10:23 AM
Looking for a hard drive...20-30 gb PureVenom Mustang Parts for Sale and Wanted 7 08-03-2005 12:28 PM
how hard would it be?? fast64 The Bar 21 01-10-2004 03:49 PM
05:26 PM
