Window Motor - Mustang Evolution
Old 05-04-2007, 10:20 PM   #1
Window Motor
My driver's side power window will not stop running unless I release the button. What is the cause of this? Also, will a 2000 GT leather back seat fit in my 97 coupe? Thanks
Pizon is offline   Reply With Quote
Old 05-04-2007, 11:11 PM   #2
Stumpy's Avatar
Re: Window Motor
normally if you are holding the button, it will continue to run. care to elaborate on your problem. the problem, the way you stated it, seems a little vague.
~Roman~
2003 Mustang V6 Vert with a Flowmaster Super 40 series dual exhaust
I'm not a target in the sights of your mercy. I've never asked for anything. I'm not asking now.
Stumpy is offline   Reply With Quote
Old 05-04-2007, 11:27 PM   #3
Re: Window Motor
When I push the button to make the window go up, the motor continues to run and makes a loud thumping noise, almost like it doesn't know the window is all the way up. The passenger side works fine; no noise once the window is fully up. Hope that is a better description.
Old 05-04-2007, 11:29 PM   #4
Stumpy's Avatar
Re: Window Motor
it is. check the regulator. it may be going bad. see if there is some slack in it. if so, change it. if not, then i will step aside and let someone else take a crack at it.
~Roman~
Old 05-04-2007, 11:32 PM   #5
Re: Window Motor
Once the door panel is removed, where is the regulator located? Also, do you know if a 2000 GT leather rear seat will fit into my 97 coupe?
Thanks
Old 05-04-2007, 11:33 PM   #6
Stumpy's Avatar
Re: Window Motor
no clue on the seats. the reg should be coming off the motor. i believe it is a couple of cables attached to your window track.
~Roman~
Old 05-04-2007, 11:35 PM   #7
Re: Window Motor
Thanks Stumpy, now at least I have a starting point!
« magnaflow?? | also! »
Will I have to replace the window motor? Sam09 Pre-2005 V6 Mustang 7 02-20-2009 10:47 AM
Power window motor Foxone Pre-2005 V6 Mustang 16 02-10-2009 01:56 PM
Window washer motor Scut95 1979-1995 Mustang GT 0 11-20-2007 08:59 PM
Power Window Motor Pizon Pre-2005 V6 Mustang 8 05-16-2007 10:19 PM
driver side window motor / switch ? Dark02Pony Pre-2005 V6 Mustang 2 06-21-2005 10:02 PM
07:44 PM
