Power Window Motor - Mustang Evolution
Old 05-05-2007, 04:14 PM   #1
Power Window Motor
How do I get to the window motor. I've taken the door panel off, but there's a metal frame with bolts all over the place and the motor behind them all.
Pizon is offline   Reply With Quote
Old 05-05-2007, 04:41 PM   #2
Re: Power Window Motor
Oooo....it's a pain...
I've never gotten around to changing mine, but if you are having problems with it freezing up (leaving the window down), tap on the motor slightly and it should fix your problems.
Old 05-05-2007, 05:35 PM   #3
The problem is that the motor continues to run, making a loud thumping noise, until I release the button. It's like the motor does not realize the window is all the way up.
Old 05-05-2007, 07:20 PM   #4
hottcobra's Avatar
it sounds like one of the gears on the window regulator is stripped. you have to remove the whole metal plate to access the regulator on the back side
Old 05-05-2007, 08:51 PM   #5
Thanks, but how do I remove the metal plate? It seems that most of the bolts hold part of the window crank mechaism onto the frame. I don't see how the metal frame will come off the door itself.
Old 05-07-2007, 04:09 PM   #6
hottcobra's Avatar
their should access holes for the bolts that hold the glass unbolt the glass remove the glass & then the panel
Old 05-10-2007, 10:18 PM   #7
Send a message via Yahoo to mnsofaking
this is the step by step removal and installation of the window regulator
REMOVAL
1. Remove front door window glass.
2. Disconnect the front window regulator wiring.
3. Remove window regulator equalizer arm bracket.
4. Remove the four rivets attaching the front door window regulator to the inner door panel. Remove the center pin from each rivet with a drift punch. Using a 1/4-inch drill, drill out the remainder of the rivet, using care not to enlarge the sheet metal retaining holes. WARNING: IF THE REGULATOR COUNTERBALANCE SPRING MUST BE REMOVED OR REPLACED FOR ANY REASON, MAKE SURE THAT THE REGULATOR ARMS ARE IN A FIXED POSITION PRIOR TO REMOVAL TO PREVENT POSSIBLE INJURY DURING C-SPRING UNWIND.
5. Remove the front door window regulator from the front door access hole.
INSTALLATION
1. Install front door window regulator through the access hole in the front door.
2. Tighten to 10-14 N.m (89-123 Lb-In) . Position the regulator base plate to the inner door panel and install four rivets. NOTE: 1/4-20 x 1/2 inch screws and 1/4-20 nuts and washers may be substituted for the rivets.
3. Install front door window glass.
4. Connect the front window regulator wiring.
5. Cycle the front door window glass for proper operation.
6. Install the front door trim panel and watershed.
mnsofaking is offline   Reply With Quote
Old 05-11-2007, 01:05 PM   #8
Thanks a lot.
Old 05-16-2007, 11:19 PM   #9
np at all glad i could help
Rear Passenger power window motor failure drnelsen 1996-2004 Mustang GT 5 06-26-2009 09:08 PM
Power window motor Foxone Pre-2005 V6 Mustang 16 02-10-2009 02:56 PM
Passenger side power window motor replacement jaykay 1979-1995 Mustang GT 1 10-18-2008 03:40 PM
Window washer motor Scut95 1979-1995 Mustang GT 0 11-20-2007 09:59 PM
Window Motor Pizon Pre-2005 V6 Mustang 6 05-05-2007 12:35 AM
05:50 PM
