Missfire Cylinder 1 - Mustang Evolution
Old 05-13-2007, 04:29 PM   #1
BruThru2002's Avatar
Send a message via AIM to BruThru2002
Missfire Cylinder 1
Had code P301 pop up the other day and I have been trying to figure out what is the cause. I have replaced the spark plugs, wires, coil pack and O2 sensers. Car runs alot better now then it was, but the code is still poping up. Also, I have P1413 up too. Checked the pipe for holes, got a new pump but the code is still up. Any ideas? Thanks for your help
2000 Mustang....
~ Performance Red, New Mach 1 (Mag 500) rims, Dual Flowmaster Exhaust, Black Letters & Rocker stripes, Sony - Rockford Fosgate system
-Billy
BruThru2002 is offline   Reply With Quote
Old 05-13-2007, 04:30 PM   #2
bullitt482's Avatar
Re: Missfire Cylinder 1
Coil packs, if v6's even have them?
01 Bullitt
Old 05-13-2007, 05:15 PM   #3
Nope, no coil packs on V6, distributor type setup.
Hm...I don't have a clue man.
Old 05-13-2007, 05:39 PM   #4
rocknbronco's Avatar
What about some EGR issues????
rocknbronco is offline   Reply With Quote
Old 05-13-2007, 06:09 PM   #5
bbunt302's Avatar
On a 2000 V6?
"J" looks an awful lot like a coil pack to me. :dunno:
Scary stuff.
Old 05-13-2007, 07:41 PM   #6
Have you recently changed the crank pulley to an under drive pulley? If you dont tighten it down good (125ftlbs or so) then it can trip a miss fire code as the sensor on the crank doesn't align right with the crank sensor.
Old 05-14-2007, 05:32 AM   #7
dont have an aftermarket pulley, but ill torque it down just to see if it might help. Im going to play around with it later tonight to see if i can find something but right now im still shooting in the dark. Thanks for the posts.
2000 Mustang....
-Billy
Old 05-14-2007, 08:43 AM   #8
Originally Posted by bbunt302 View Post
On a 2000 V6?
I was thinking coil over for some reason....ignore me...
Old 05-14-2007, 08:28 PM   #9
pulley is tight... still has a code and does stumble a little when crusing around 1500 rmp... any other thoughts?
2000 Mustang....
-Billy
Old 05-14-2007, 08:42 PM   #10
fuel system? changed the fuel filter as of late. You can also clean your maf sensor.
Old 05-14-2007, 11:45 PM   #11
I_luv_HP&trq's Avatar
Send a message via AIM to I_luv_HP&trq Send a message via MSN to I_luv_HP&trq
you guys have coil pack(s) just not coil over plugs.
I'd disconnect the battery for a few minutes while clean your Iat and Maf sensors. Recheck wires and plugs?
99 Cobra: flowmasters, 18x9.5 cobra R's, soon to be tuned and geared. daily driver
99 V6:in avatar, Mac Cai, true duals/flowmaster 40's ,UDP, custom tuned, bullitt suspension 18" wheels...taken by mother nature
I_luv_HP&trq is offline   Reply With Quote
Old 05-15-2007, 08:07 AM   #12
Definatly check the IAT sensor (cylinder shaped thing on the throttle body) if its clogged up it can alter the idle ability of the car. Mine went out and the car just would not idle.
Old 05-15-2007, 04:36 PM   #13
bullitt482's Avatar
IAT or IAC? Inlet air temp or Idle air control? Just to be sure.
01 Bullitt
Cylinder Misfiring? Jeremym831 1996-2004 Mustang GT 4 02-05-2008 01:12 PM
New Cylinder Heads V6Polish Pre-2005 V6 Mustang 5 06-24-2007 02:28 PM
P301 Missfire Cyl. 1 BruThru2002 Pre-2005 V6 Mustang 3 06-06-2007 08:40 AM
92 four cylinder problem Ponyboy86 Pre-2005 V6 Mustang 11 03-23-2005 02:45 PM
cylinder heads. which ones better? rasputinlv Pre-2005 V6 Mustang 11 02-26-2005 12:41 PM
09:32 AM
