Tranny Problem? i think... - Mustang Evolution
Old 05-16-2007, 03:32 PM   #1
Hey guys this is the deal... when the clutch is released no matter whether I am accelerating or not there is a rattling noise, but when I push it down, the sound goes away... it basically only happens when the clutch is released, whether in gear or not, im pretty sure. but I was hoping someone could give me some info if it could be easy fix or big problem?
DMAC is offline   Reply With Quote
Old 05-16-2007, 04:00 PM   #2
Re: Tranny Problem? i think...
It sounds to me like a throw out bearing issue. Does the clutch have a good bit of flop in it when it is out aka you can lift up on it from the bottom or it takes a bit of pushing it in before it starts to go into neutral?
The throwout bearing is a very cheap part its just getting to it... you have to take out the transmission. You should also do a clutch swap while you are at it and change out the pilot bearing, check the input shaft play, and the bearing retainer sleeve for wear.
Old 05-16-2007, 04:08 PM   #3
how much would doing all of those things cost around? poor college student home with summer job, i got a good guy who could do it just trying to get a close figure if i went to like ford or something?
tranny problem ? 1 dark demon 2005-2010 Mustang GT 21 10-31-2008 03:03 PM
Tranny/Shifter problem... Fast93Coupe 1979-1995 Mustang GT 6 04-22-2006 04:26 PM
Shifter clutch or tranny problem??? PA6shooter Pre-2005 V6 Mustang 10 04-28-2005 09:15 AM
tranny problem? 232SCstang Pre-2005 V6 Mustang 3 03-15-2004 02:15 PM
Tranny Problem.... v6mustangguy Pre-2005 V6 Mustang 16 01-31-2004 07:11 PM
07:29 AM
