this maybe a stupid question.. - Mustang Evolution
Old 05-17-2007, 11:03 PM   #1
iwannagofast's Avatar
ok so i have a 2004 V6, now is it a 3.8 or 3.9? i thought all V6 stangs from 94 and up where 3.8s, but some people are posting V6 stating its a 3.9
iwannagofast is offline   Reply With Quote
Old 05-17-2007, 11:06 PM   #2
meteorachick's Avatar
Re: this maybe a stupid question..
in 2004, in the june+ (i think june) they used left over winstar parts and made some v6 engines 3.9, for example, i have a 3.8 and my sister has the same exact car and has a 3.9. if you open the hood, it should be right in there, right on a sticker near where the hood latch is
Modified 2004 V6
Old 05-17-2007, 11:12 PM   #3
Yupp.
It does not make a single difference at all, in any way, in any form, in any fashion, in any altitude, in any latitude, in any longitude, in any anything. Period. Forever.
Amen. Period.
Old 05-18-2007, 12:04 AM   #4
Yupp.
Amen. Period.
thats funny, you re right , but its funny how you said it..."....in any way, in any form, in any fashion, in any altitude, in any latitude, in any longitude, in any anything..." JAJJA
carlosc is offline   Reply With Quote
Old 05-18-2007, 06:46 AM   #5
Just wanted to clarify for people. Any engine part you might buy should be for an 01+ 3.8/3.9. That's when they changed the crank balancer.
Any intake for a 99-04 V6 mustang will work. Any upper/lower intakes for a 99-04 v6 Mustang will work.
Old 05-18-2007, 05:23 PM   #6
Send a message via AIM to Zuperzacker Send a message via Yahoo to Zuperzacker
well, there is one difference, it takes an extra tenth of a liter of oil to fill up ur system
Zuperzacker is offline   Reply With Quote
Old 05-20-2007, 10:20 PM   #7
Uhm.........no.
Old 05-21-2007, 07:12 AM   #8
Dont put oil into your car until it comes out of the valve cover. Even then the displacment of an engine is the amount of air it displaces not the size of the crank case.
Old 05-22-2007, 05:20 PM   #9
bullitt482's Avatar
/\ Correctomundo Displacement= bore x bore x stroke x .7854(or pi divided by 4) x number of cylinders
01 Bullitt
Old 05-23-2007, 06:23 PM   #10
I wasnt referring to the displacement, i was actually referring to the fact that the average car takes two more liters of oil than its given displacement, this is a general rule if no set numbers are available.
(although this was developed while working on GM vehicles, so may not hold true to Fords)
Old 05-24-2007, 04:59 PM   #11
bullitt482's Avatar
I see where you are coming from now. . Sounds more like what it should be on every vehicle, IMO. Although 7 quart oil changes get expensive.
Definately not true for Fords. I put about 4 and a half quarts in the notch(stock size oil pan and still 5.0) and just under 5 quarts in the Bullitt(4.6).
01 Bullitt
Old 05-25-2007, 04:28 AM   #12
I put a full 5 in the 3.8. That's how I've always done the car and she's never complained.
Old 05-25-2007, 07:03 AM   #13
Put it in until its full on the stick then stop, every car is a bit different. Mine takes right at 6 quarts.
Old 05-25-2007, 08:45 AM   #14
rydog's Avatar
Send a message via MSN to rydog
Same here and i dont add any extra for the turbo feed and drain lines
97 V6-GT40 turbo-42#rs-BA2800 MAF-4.10's & tlok-254rwhp-369rwtq
Turbo'd by-TMA Turbo(http://www.tmaturbo.com/)
Tuned by-Dyno Tuned Performance(http://www.dtpracing.com/)
rydog is offline   Reply With Quote
Old 05-25-2007, 09:00 AM   #15
Y2E0L0L5OGWT's Avatar
mine takes just a tad over 6 quarts (6.3ish) woohoo! I got you all beat!! suck it! mine is bigger than yours! lol
(sorry, I am bored at work)
Old 05-25-2007, 10:56 AM   #16
Like i said, rule of thumb developed for GMs while working over the summer, (these were mostly light duty trucks) so they probably had proportiantely larger oil pans
Old 05-25-2007, 11:00 AM   #17
Mine takes 6.5....so...
/thread
Old 05-26-2007, 03:17 PM   #18
bbunt302's Avatar
I hope you guys aren't going by what the dipstick says is "Full" on a Ford vehicle. They are notoriously wrong. Full is actually a decent amount below full.
Put in what the manufacturer tells you to in the maintenance manual, which is 5 quarts for a 5.0L and 6 for a 4.6L.
Scary stuff.
Old 05-26-2007, 03:26 PM   #19
Did something chance between 99 and 03 because my old 99's owners manual called for 5 quarts and my 03's owners manual calls for 6 quarts in the 4.6's. It doesn't specify between SOHC and DOHC either and it also tells you the amount for the V-6's which leads me to believe that both 4.6's use the same amount of oil? :dunno:
JROC is offline   Reply With Quote
Old 05-26-2007, 03:28 PM   #20
bbunt302's Avatar
Maybe so. I just know that my '06 uses 6 quarts and I thought I have heard of others using the same amount. It's kinda weird that it changed between '99 and '03 though.
Scary stuff.
Old 05-26-2007, 06:58 PM   #21
90% of the time or more sticking what they recommend is perfectly fine, some take a little more but... my bet is on the dipstick being off vs the size of the oil pan.
Old 05-26-2007, 08:59 PM   #22
My 00 GT took 5 quarts as well...I will have to check the manual in the 02 GT and see what it calls for. I believe when I changed it last...it took 5 if I remember right. Gonna have to check again.
Old 05-26-2007, 09:04 PM   #23
Yeah my dad has a 97 F-150 with a 4.6 and I'm pretty sure it only holds 5 but I could be wrong. I changed my oil today and put 6 quarts in it and it only went about 1/3 the way up inbetween Min and Max.
Old 05-26-2007, 09:09 PM   #24
It takes 6.5 qts to get mine up above the full line. Seems like about every car is different too.
Old 05-26-2007, 09:18 PM   #25
DarkShadow's Avatar
Send a message via AIM to DarkShadow
I put in right at 5 with mine too. Before I put the turbo on, I was expecting to have to add as much as another half quart LOL! But instead it still takes just the same :dunno:
DarkShadow is offline   Reply With Quote
Old 05-27-2007, 02:26 AM   #26
rocknbronco's Avatar
Exactly also if you plan on doing any auto crossing or hard road racing add an extra quart to fight oil strarvation I am also sure this rule applys to drag racing.
rocknbronco is offline   Reply With Quote
stupid question...... JTATE300 Pre-2005 V6 Mustang 36 04-14-2010 02:32 PM
stupid question SaturnMan8227 Pre-2005 V6 Mustang 0 01-20-2009 11:43 PM
Stupid Question 1234 1996-2004 Mustang GT 34 07-15-2008 02:45 PM
here goes a stupid question Kyle Pre-2005 V6 Mustang 9 03-13-2007 08:08 PM
Stupid Question.... tkd_gt 1996-2004 Mustang GT 23 08-05-2006 10:50 AM
05:06 PM
